Top Brands for Intercooler
Old May 14, 2018 | 03:58 AM
Bananaevo9's Avatar
Hello guys
I am currently running a stock intercooler on my Evo 9 which makes 400hp. I would like to ask you what brands you consider to be the most reliable for aftermarket intercooler. I have heard some very good comments for the following brands: Sheepey Built, ETS, Mishimoto. If you have one of those, or anything else please share your experience/view. Any comments are more than welcome.
*** Please have in mind that I am living in Israel where the summer temperature is between 42 to 47 celsius. So, you can understand that any cooling part that I am going to install needs to be made from outstanding quality/brands materials.
Thanks for your time
Old May 14, 2018 | 06:45 AM
2006EvoIXer's Avatar
I don't think there are much difference between brands. What affects efficiency are size, thickness, and type (bar&plate vs fins). Bigger is better at cooling and fins do a better job than bar&plate.
Old May 14, 2018 | 07:48 AM
This topic has been discussed and debated. I will have to go back & find the articles, but I believe the Bar /Plate will out perform the less expensive Fin design in most categories
Old May 14, 2018 | 08:00 AM
RazorLab's Avatar
I have some data that shows the opposite, at least in my experience:
https://www.evolutionm.net/forums/pr...l#post11818999
Old May 14, 2018 | 08:04 AM
There are many opinions, but heres a decent article worth reviewing
http://www.superstreetonline.com/how...p-intercooler/
Old May 14, 2018 | 08:10 AM
RazorLab's Avatar
My post wasn't an opinion? It has data in it.
Old May 14, 2018 | 08:13 AM
Even our YT Engineer has an opinion on this topic
Old May 14, 2018 | 08:24 AM
Bar & plate has more mass so it can cool longer for drag race where it can cool down between races. Fin design has better heat transfer rate so that's better for road coarses. OP has desert temps so neither has much efficiency. E85 is his best bet.
Old May 14, 2018 | 09:17 AM
From my chair, yes, your opinion counts. Read your post & it has good info
Ive been running an old Nisei FMIC & all the pipes. Its a super robust FMIC & is a Bar & Plate design
Old May 14, 2018 | 06:01 PM
Saltyevo's Avatar
In my opinion ETS is the best bang for your buck. Very affordable good product. Any fabrication company can make a good intercooler but I think the ETS's are on the more affordable side. I run an ETS.
Old May 14, 2018 | 08:25 PM
Bananaevo9's Avatar
Guys I am a little bit confused. You are referring to bars and plates. I don't want to review each component of each intercooler to assess which is the top one. I want to know as an overall result which one produces the best results.
thanks
Old May 14, 2018 | 08:41 PM
thanks
they're all about the same. Get which ever fits your budget. The bigger the unit's volume, the better the efficiency.
Old May 14, 2018 | 08:42 PM
To be honest, I don't know how you are able to make 400 hp with stock intercooler. What fuel was that 400 hp made on?
Old May 14, 2018 | 08:50 PM
LetsGetThisDone's Avatar
E85, stock turbo, bolt ons...
Old May 14, 2018 | 09:33 PM
If he's on E85, upgrading intercooler won't net him much for the cost. He'll get better bang on 71HTA.
