Clutch fork postion...
Old May 29, 2018 | 07:59 AM
black_beauty's Avatar
I know this subject has been beat on and I’ve searched and read all my little brain can comprehend. I’m mating the motor and trans back together and I can get the fork to seat in the middle but it doesn’t take much pressure to push it back to the passenger side of the car. I can move it with my finger. If it’s seated in the middle, I can push to the pass side of the car and it clicks and moves toward the pass side.
Old May 29, 2018 | 09:53 AM
barneyb's Avatar
Put a deep well socket over the end of the arm and give it a good tug. If it doesn't lock in you need to pull the transmission and check what's wrong.
Old May 29, 2018 | 10:32 AM
I’ve done that and tapped it with a block of wood/hammer, it won’t go any further to the driver side then the 1st picture. It will hold in the middle but it doesn’t take much pressure to push it back the the pass side, 2nd picture...
Old May 29, 2018 | 10:38 AM
badev0's Avatar
It sounds like you have an issue with your TOB or the clip on your pressure plate. Time to pull the trans and inspect.
Old May 29, 2018 | 01:03 PM
barneyb's Avatar
I broke a wedge collar trying to stab my transmission. Parts then fall down inside of the clutch. A monoloc is pretty unbreakable. Which are you using?
Old May 29, 2018 | 02:52 PM
I’m using a mono-loc. Clutch and pp are brand new.
Old May 29, 2018 | 03:23 PM
barneyb's Avatar
The only trouble I ever had with a monoloc was getting it to release. I don't know what's different but there's a monoloc for the 8 & 9 and another for the 10. I've used a couple and the install was straight enough. They did take a little force, it sounds like you are using enough.
bostonhatcher
Jan 4, 2015 01:22 PM
EVOEvolved
Mar 30, 2014 07:44 PM
teddy
For Sale - Wheels / Tires
Mar 4, 2008 02:08 PM
Mitchubishievo
33
Jul 1, 2007 10:37 PM
nick735
16
Mar 21, 2007 01:29 PM
