Gates Timing Belt noisy af
Old Jun 3, 2018 | 09:16 AM
palaBoost's Avatar
Smile Gates Timing Belt noisy af
After spending a whole day taking on this timing belt job. I got a good tension on the belt, not too tight nor too loose but this is what it sounded like. Normal?
Old Jun 4, 2018 | 08:56 PM
AustEvo's Avatar
Don't think that's your belt making the noise. Did you replace the pulleys too? If not you should.
I just replaced everything and there's no noise.
Old Jun 5, 2018 | 07:21 AM
badev0's Avatar
Definitely not normal. Sounds like a bad tensioner or idler pulley.
Old Jun 5, 2018 | 08:47 AM
kyoo's Avatar
just had all belts and pulleys done with gates belts here. I have no abnormal noises
Old Jun 5, 2018 | 08:01 PM
barneyb's Avatar
Your not the first, there's other threads here reporting the same problem with people replying either that they don't have the problem or writing they solved it by switching back to OEM. I have no experience with the Gates belt.
Old Jun 6, 2018 | 07:31 PM
hutch959's Avatar
sounds to tight.
maybe a tension problem
Old Jun 26, 2018 | 11:58 AM
Nexx896's Avatar
Sounds like its too tight, or the bearings are bad.
Jmills
25
Apr 17, 2015 06:58 AM
BbotVIII
11
Jan 16, 2015 10:19 AM
evotris
29
Sep 8, 2013 07:26 AM
DSMdynamic
Apr 23, 2012 02:58 PM
StevenStarke
Dec 4, 2008 01:58 PM
