Intake manifold brass plug boost leak
Wonder if a little JB Weld would suffice for the short term? You can tell by the dip stick spring that you must be running some high boost. Above 30?
Also, how was that Mani painted (was it powder coated?) I ask only due to the high temps for the PC process
I was thinking JB weld for a temp solution but didn’t want to mess it up for welding repairs. Only running 25 lbs with pump gas on built 2.3. Found this leak due to building up boost and my AFR dropping to low 10’s. I had this car tuned about 2 weeks ago after the motor build at English racing and was running well till about 3 days ago. I’m waiting to pick up my catch can this coming weekend in hopes that I won’t have to run the spring anymore. I painted the manifold with VHT wrinkle black as it had some black paint prior to my ownership. Thanks!
McDougal
Oct 14, 2009 09:27 AM
SzuChenEvo
Mar 29, 2006 02:24 PM
Sano
May 25, 2005 10:30 AM
Mike@Forge
12
Mar 25, 2005 09:17 PM
