Change crankshaft seal with timing belt
Hi all,
About to do the timing belt (daily driver, 96k miles). Gonna do the works while I'm in there. A mechanic friend (who doesn't know Evos but is a pretty good mechanic) suggested I do the crankshaft seal while I'm in there. I haven't seen much discussion of that in the timing belt threads I've read.
Do you all usually replace that with the timing belt?
Is it difficult?
Or is it more trouble than it's worth if it's not leaking?
Thanks,
Anthony
Is it difficult?
Thanks,
Anthony
I'm planning doing timing belt/balance/pullies/tensioner/waterpump, the whole shebang for 120k miles maintenance. Since i'm in there, should the front seal be replaced? I'm under 350 whp, mostly bolt ons
might as well replace the oil pump, and gaskets too...... oil pump cover comes with new seal.
It's easy enough to. Might as well.
LMAO, the oil pump is not a "might as well" replacement part. $240 for the pump/case, and multiple additional hours pulling the oil pan and various other parts. 0/10; do not recommend unless there's an ACTUAL failure/reason to do so.
anthonypazsd
135
Apr 2, 2026 12:56 PM
evotris
29
Sep 8, 2013 07:26 AM
Robertv34
Aug 27, 2011 12:55 PM
PSG Evo
16
Feb 6, 2011 09:28 AM
anthonypazsd
Jan 31, 2010 03:01 AM
