In need of an oil catch can. What do yall use?
Old Jun 19, 2018 | 09:19 PM
Womb Raider's Avatar
Veteran: Marine Corp
My dip stick keeps popping out under boost. Had to put a spring on it to hold it down. Which is why im looking for a catch can to help out with the crank case pressure.
im looking at sheepey builts atm.
Inputs? What do you all use?
Old Jun 20, 2018 | 02:46 PM
heel2toe's Avatar
A catch can doesnt necessarily assist lowering CC pressure, but rather is used inline so you dont gunk up your intake and intercooler. Take a look at this thread here: https://www.evolutionm.net/forums/ev...re-issues.html
Personally when I blew out my dipstick I opted to open up the side vent on my VC to 5/8" and removed my baffles to clean out the VC then drilled and tapped to reinstall them. No more CC issues for me, well at least my old motor was fine with just that. We shall see how the new motor does.
Old Jun 20, 2018 | 04:22 PM
Pal215's Avatar
+1
OP, you want to find a way to place a vacuum on your valve cover without getting the intake manifold dirty. A dirty intake manifold can introduce contaminants into the cylinders and induce knock. The stock PCV system does a good job of this when not in boost, but when the boost comes on, the PCV valve shuts. That bad part about that is most of your crank case pressure is generated while in boost and has to escape from the tiny holy in the side of the valve cover. The solution, as mentioned above, is to drill out the valve cover breather. Look for a closed catch can setup that takes advantage of your engines vacuum when not in boost. One way to generate vacuum while in boost is by using a downpipe Evac scavenger kit, but that's not needed in most cases.
Old Jun 20, 2018 | 04:45 PM
hutch959's Avatar
Back of valve cover - STM -10 fitting. -10 AN hose straight to K&N filter.
Side of valve cover - Drilled 1/2" NPT thread to -10 AN, hose straight to another K&N filter.
done.
BaumBizzle
17
Sep 24, 2012 11:59 AM
anthonyrb98
50
Sep 11, 2011 07:49 AM
riceball777
14
Dec 23, 2006 09:39 PM
