Turbo upgrade, confused about bolts/ studs needed
Old Aug 6, 2018 | 11:26 AM
Meez's Avatar
I'm installing a pre-owned OEM Evo 9 turbo on to my Evo 8. The Evo 9 turbo comes without any bolts, and the previous owner has removed the studs as well :/
Does anyone know if I can get away with just using new bolts to mount the turbo in place instead of using studs?
Specifically, can I just use these for both bolt and stud locations? https://www.maperformance.com/produc...-evo-8-9-and-x
Any idea how many of these bolts are needed?
And how many turbo to O2 housing bolts are needed?
Old Aug 6, 2018 | 11:31 AM
GSX_TO_EVO's Avatar
You can not use the above for the stud locations, but you can use bolts instead of studs.
You will need 5 bolts for the 02 housing area, and 4 manifold to turbo bolts.
Old Aug 6, 2018 | 11:39 AM
LetsGetThisDone's Avatar
You can get all the appropriate studs, bolts, nuts and washers from STM. Just give them call.
Old Aug 8, 2018 | 02:35 PM
Meez's Avatar
Do you mean I can simply use bolts, while leaving the stud locations empty?
Old Aug 8, 2018 | 02:57 PM
You would use bolts instead of studs. You need all 4 pieces of hardware hold the turbo on or it will blow the gasket out..
