Evo 8 trouble starting
Old Oct 10, 2018 | 06:30 PM
Project_Broke's Avatar
Originally Posted by barneyb
You are right, I read it as MAF.
You don’t slip often. Gotta keep you accountable.
Old Oct 11, 2018 | 11:15 AM
BTW_Evo8's Avatar
Originally Posted by maxroach
How did you check your vacuum lines?
I would say this is vacuum leak.
Perform full vacuum leak test from turbo.
Goodluck
so I performed a leak test and couldn’t find anything. Also got a diagram of all the vacuum lines and traced every single one of them. Didn’t find any cracks or loose hoses, so I couldn’t imagine it being a vacuum leak at this point.
Old Oct 12, 2018 | 05:51 AM
If it's coding for the MAP sensor, check the wiring and replace the sensor.
It can, and will reek havoc on drive ability.
Old Oct 13, 2018 | 12:47 PM
BTW_Evo8's Avatar
ok man, I’ll double check wiring and prob try replacing it first. The input is much appreciated! Thanks
