Rod bearings.
Old Oct 15, 2018 | 03:06 AM
Sheikh Zaeem's Avatar
Rod bearings.
Hey guys.
i have a stock 03 evo VIII, i was running it on 1.2 bar for 6 months and two weeks back #1 rod bearing went bad.
i had a rebuild with new crank and acl STD bearings and new oil pump.
on the first run the #1 rod bearing went again.
please guide me on what could be the reasons behind this.
pictures are attached.
Old Oct 15, 2018 | 04:56 AM
Project_Broke's Avatar
Was it the same rod?
Big end may be out of round, I would tend to say oil starvation, but I don't see much heat there.
Old Oct 15, 2018 | 05:13 AM
Welcome to EvOM
Understand you have a rod bearing issue but wonder if the block was "aline honed" / truing up the main bearing caps?
When the crank was installed, was there proper endplay recorded?
Old Oct 15, 2018 | 06:23 AM
Evo8cy's Avatar
You need to check the block and girdle and make sure they are within spec.
Marios
