Tapping sound from 3000-6000 RPM!
#33
This is what my engine sounds like at idle. Evo ix with S2 cams.
https://youtu.be/DWcNN06-YMo
#37
Running without oil or coolant will seize the engine. If you didn't do that then maybe the engine isn't seized. It could be that one of the accessories or idlers on the serpentine belt has locked. Pull the belt and check if everything spins freely.
