Hesitation after turbo swap
Old Jan 25, 2019 | 08:34 PM
  #31
bishop9d4's Avatar
Old Jan 25, 2019 | 09:44 PM
  #32
bishop9d4's Avatar
https://m.youtube.com/watch?v=fIB_DyiUxEs
This is after I tightened everything
Old Jan 27, 2019 | 10:05 AM
  #33
2006EvoIXer's Avatar
Greddy install looks good. How stiff is the spring inside?
Old Jan 27, 2019 | 10:07 AM
  #34
Was this at WOT?
Old Jan 27, 2019 | 10:09 AM
  #35
bishop9d4's Avatar
I have it stiff but im. Going to soften it up and see if I can get rid of the flutter. Car steams. To have some. Lag but I still. Need a tune also. But it's better than when I first put the turbo on
  #36
bishop9d4's Avatar
Originally Posted by 2006EvoIXer
Was this at WOT?
No ooooo don't have a tune yet for wot pulls
Old Feb 8, 2019 | 04:56 PM
  #37
bishop9d4's Avatar
OK so I finally found the issue. There was a hole in the air filter but not like you would think. There was a split in the seem if the filter the long way. Only reason I found iot was cause when I took it off to check the intake my 5 year old said daddy what's this and had pulled it apart. Changed the filter and now things are perfect.
Old Feb 8, 2019 | 08:45 PM
  #38
Jonno99's Avatar
ok so your 5 yr old found the problem, you might need to hand the car down to him in 10 yrs
Old Feb 8, 2019 | 08:49 PM
  #39
kaj's Avatar
kaj
