Hesitation after turbo swap
Old Dec 25, 2018 | 11:21 AM
TomekEVO's Avatar
the symptoms you are describing are of a huge boost leak imo
Old Dec 27, 2018 | 11:01 AM
bishop9d4's Avatar
Found one issue the preload on the turbosmart IWG75 was wrong. Fixed that but I still here something other than the turbo and the bov still sound weak
Old Dec 27, 2018 | 11:19 AM
LetsGetThisDone's Avatar
You need to do a boost leak test...
Old Dec 27, 2018 | 12:19 PM
kaj's Avatar
kaj
Let's revisit:
Originally Posted by kaj
My best guesses:
Massive boost leak....
You did a boost leak test?
99% of the time it's a boost leak...
If you have a bad enough boost leak, the turbo could be spinning 1,000,000RPM and sucking a ton of air, which could be pretty noisy.
It may not be a boost leak, but it's still the FIRST thing you check, always.
Old Dec 27, 2018 | 01:19 PM
bishop9d4's Avatar
Doing that now
Old Dec 27, 2018 | 01:51 PM
kaj's Avatar
kaj
Originally Posted by bishop9d4
Doing that now
Good luck ,dude! Hopefully just a loose coupling.
Old Dec 27, 2018 | 06:09 PM
2006EvoIXer's Avatar
Let's revisit:
Old Jan 8, 2019 | 06:31 PM
bishop9d4's Avatar
OK so i took a video after i checked and rechecked EVRYTHING!!!! I cannot figure this shyt out. In the video what you here is me at 3+k turbo working like hell but no Blow off and no real movement. Turbo id spinning and at 4k the wg aint even opening. WTF am i missing?
Old Jan 8, 2019 | 11:05 PM
kaj's Avatar
kaj
It's been a while..but if no DV sound, is it leaking?
Old Jan 9, 2019 | 04:57 AM
bishop9d4's Avatar
I'm. Gonna put the stock valve on today to rule it out
Old Jan 9, 2019 | 10:07 AM
kaj's Avatar
kaj
Something is leaking like crazy and not holding boost. I bet your load values are off the chart. Just take it easy so you don't kill the turbo
Old Jan 9, 2019 | 10:23 AM
Pictures of your engine bay? Did you install your DV backwards?
Old Jan 9, 2019 | 10:41 AM
Evo8cy's Avatar
The hissing sound could be a leak, it might as well be the hta71 through the specific filter you are using. If you have increased boost threshold and not making the right boost level at the right rpm point, then you have a leak somewhere. Remove blow off valve and block the pipe. Check every hose connection, every vacuum hose. Put the car into 2nd and floor it, see if it behaves as it should. If not, remove the hose from the wastegate nipple, again into 2nd and floor it, see if it makes boost the right way.
His load values will not be negatively affected if he has a major leak, as the air going into the engine and measured by the map sensor is much less than it should when his boost threshold and max boost was the proper one, unless of course he is still on MAF.
Marios
Old Jan 25, 2019 | 08:31 PM
bishop9d4's Avatar
I'm running a greddy type rs
Old Jan 25, 2019 | 08:32 PM
bishop9d4's Avatar
