I use 4G69(NA4W) throttle.
Fit on OEM elbow. It is a little tight.
It is the same mounting pitch.
This is APS wiring diagrams same as evo10.
pin 1 : +5V
Pin2 : Sensor Ground
Pin3 : APS (Main)
pin 1 : +5V
Pin3 : APS (Sub)
One last question btw, what are the colors on the cables? Is ut thw same colors for the pedals aa to the throttle body? Does it matter if i use or evo gasket? 4g69
I am not fit the throttle on my car , I am making a harness now.
Therefore, although the color of cables is not decided, I plan to use ISC wiring for throttle.
The wiring of the pedal was made with the stock wire.
I will use 4g69 gasket.
nice work man. do you have the part number for the gasket by any chance?
Bit of a thread revive, following for Pedal mounting solutions on a CP (E5/E6)
I currently have an Evo x pedal but from the looks of it I may have to do some cutting to fit the pedal where the oem one is.
I'm converting my evo ix, using a Haltech, evo x pedal, and an 82mm bosch motorsports TB from a Porsche application.
Question. Is the plug the same between the evo x accelerator pedal and the evo x tb? (I only have a pedal, so I cannot verify) It appears the electrical plug on the pedal has an extra keyed feature from the plug that is referenced above from the aftermarket source.
This is a pic from earlier this summer. All i can say that it is tight as f*ck between the fuel rail and throttle body. My friend is gonna cut of the stock gas pedal that weld on a new plate so i can bolt up the. E gas pedal. Thanks btw for the link to the gas pedal connector i bought the wrong one
You an get a spacer made or buy one to push the tb away from the rail. I gonna do that to make sure the magnus one works. Thats the 4g96 one on there right?
