Stock Frame Turbo Upgrade Suggestions
Old Feb 7, 2019 | 03:26 PM
ctfpevoVIII's Avatar
Originally Posted by ayoustin
It's waaaay more fun on E85. Buy a 55 gallon drum, fill it with E85 and put it in your garage. That's what I did when the closest pump was 30 miles from my house.
man I wish I had it within 30 miles but the closest is more like 80-100 miles a bit far! But yeah I have contemplated getting a 55 gallon drum, who knows maybe I will someday. I’m sure it is a lot more fun as who wanted want like another 100 hp! Haha
Dallas J's Avatar
Veteran: Army
Or get 55gal drum of E98, mix 50/50 with premium and get all same benefit with it lasting a fair bit longer. (I plan to do this eventually)
Old Feb 7, 2019 | 03:36 PM
Ayoustin's Avatar
Meth kit is always an option too. Plus it can last a while since you're only spraying when you're above a certain boost level.
Old Feb 7, 2019 | 03:47 PM
Dallas J's Avatar
Veteran: Army
Meth is a helluva drug
Old Feb 7, 2019 | 04:13 PM
Construct's Avatar
Logistically, how do you get that drum into your garage? Is there an easy, safe to unload a 400lb drum of fuel from my pickup bed by myself?
Old Feb 7, 2019 | 05:28 PM
Wicked_X's Avatar
I'm so grateful to have E85 all over my town. One of the few perks of being in Cali!
Old Feb 7, 2019 | 06:35 PM
Ayoustin's Avatar
Friends. 2-4 people can lift it depending on if you even lift lol
You've gotta **** up pretty backly to puncture a drum. I'd recommend using the plastic type, not metal. You can get hand pumps that attach to the barrel off amazon. Or just use an old fuel pump hooked up to an old car battery and throw some hose on it and leave it at the bottom of the drum.
Old Feb 8, 2019 | 06:24 AM
I actually run aqua mist meth kit it does help but it isn’t e85 for sure!
Old Feb 9, 2019 | 02:04 AM
Evo8life's Avatar
You can always explore other options then fp,i Run a turbo parts canada GTX3576R stock frame great turbo so far and makes good power on pump gas + 50/50 wmi and is definately cheaper then any fp turbo out there
Old Feb 9, 2019 | 10:00 AM
Vinay1789's Avatar
Thank all of you for the advice.
Ive decided to go for the RED.
Will post the results soon.
Old Feb 9, 2019 | 10:09 AM
Wicked_X's Avatar
Nice! I'll be posting my Red results most likely tomorrow. Headed to the mustang dyno in the AM
Old Feb 9, 2019 | 11:32 AM
Vinay1789's Avatar
Should i get with or without WG Actuator?
Also I would appreciate if someone can explain the difference between them.
Old Feb 9, 2019 | 12:31 PM
Wicked_X's Avatar
I went with the turbosmart 18psi WGA and it works great. When I called FP, they actually recommended I use that one.
The difference is the spring rates in them. If you get a 25psi actuator, the spring is keeping the wastegate shut until it sees around 25 psi with no preload, regardless of boost control settings. Same with the 18psi actuator. I would go with the 18psi one if you plan to run pump gas, just adds a level of safety so that the Tephramod drop boost on high knock can help you out in case you get a bad tank of gas.
Old Feb 12, 2019 | 02:02 AM
Vinay1789's Avatar
What are the general thoughts and opinions about the Tomioka TD06 20G turbo?
Old Feb 12, 2019 | 12:59 PM
Evo8life's Avatar
thats a bad choice,quiet laggy for the size of it. You can go for the turbo i mentioned early in this thread for a close price to the tomioka but will make way more power everywhere.
