Gear Linkage angle and gear selection issue
I am having some issues with selecting 2nd gear on my 5 speed gearbox, I have read that a lot of other people have similar issues until the gearbox has warmed up, but it does seem quite bad.
I have noticed that one of my gear linkages seems to be at an angle to its holding bracket on the transmission case itself, I feel as though it should be straight so that there is not resistance and not to an angle, is this normal or should it be straight? I wonder if this could be causing me the problem
I know that the cable is not bent because when I remove the eyelet from the selector pin it is returns to a normal position
any help or previous experience would be greatly appreciated
Regards Shaun
Regards Shaun
