Another boost creep issue
Old Mar 10, 2019 | 09:31 AM
blackline's Avatar
5 Year Member
Originally the car had a Megan o2 housing and I was getting boost creep because the WG opening was too small. I swapped out the stock wg and switched to a STM o2 open dump emlinator and I’m still getting boost creep.
Im not sure what else can cause the creep, I set the wg preload with 2 full turns and still can’t get it to not creep.
Target boost is 25psi but it creep close to 30psi by 6k in 3rd.
I’m not sure what else to do, any ideas?
BBK full turbo
grimspeed 3 port
turbosmart 22psi wg
SD
4 bar map
Old Mar 10, 2019 | 04:21 PM
machoymaru's Avatar
Man that sucks from my experience I had my clutch slip and that will make my boost go crazy all the way up to 30 psi. Dont know if this is much help, but I really do hope you fix it and enjoy the Evo.
Old Mar 10, 2019 | 04:39 PM
blackline's Avatar
5 Year Member
I don't think I'm having clutch issues but thank you for that input as any little bit helps.
I connected the wastegate to the jpipe today but i netted the same results. Going to apply air to the WG and see if the arm is moving and now much. Once that's done I'm going to disconnected the wg buckle and check the range of the wg flap. I'll report back soon
Old Mar 10, 2019 | 09:59 PM
2006EvoIXer's Avatar
Can't you tune the boost creep down?
Old Mar 11, 2019 | 06:05 AM
blackline's Avatar
5 Year Member
I’m not sure but running on wastegate pressure netted the same results. I’m going to pressure test the wastegate now
Old Mar 11, 2019 | 09:58 AM
heel2toe's Avatar
We discussed this in your other thread but you didn't take my advice. Your target boost is 25# yet you're using a 22# WG spring. You want your WG spring to be around half what your target boost level would be. Put back on the oem gate and try again.
Old Mar 11, 2019 | 10:38 AM
Wicked_X's Avatar
I had to run my turbosmart 18psi actuator to zero preload to help with creep from my MAP o2 housing. With even a little preload it would spike to like 24-25 psi at just wastegate pressure. I would try no preload.
Old Mar 11, 2019 | 11:02 AM
LetsGetThisDone's Avatar
You need to put a stock or lower boost WGA on it.
There's really not reason to not just run a stock actuator with only trying to run 25psi of boost.
Old Mar 11, 2019 | 12:24 PM
blackline's Avatar
5 Year Member
You're right but I was just following instruction from my tuner.
I'll try this also.
going to slap the stock gate in and see what's going on.
Old Mar 11, 2019 | 12:58 PM
heel2toe's Avatar
All good man. Baffled that's what your tuner recommended as it is a pretty elementary concept.
Just throw back on the stock gate and call it a day. I bet that will fix your issue, tuner will need to throw more WGDC into it but no biggie.
And I would not recommend running zero preload. That will promote lazy boost characteristics as there is a good chance the flapper wont even seal with zero preload. I forget how many turns but if you're looking at the arm you want the turnbuckle roughly halfway up, looking like a half moon if that makes sense.
Old Mar 14, 2019 | 02:38 PM
blackline's Avatar
5 Year Member
Looks like the Turbosmart wastegate is bad. It took 30psi to crack it and 40psi to open the gate 1/4 way, 20psi didn't do anything. Waiting on TS to warranty it. Also, my evo9 wg vacuum port is broken so I can't test with that.
Old Mar 14, 2019 | 03:07 PM
heel2toe's Avatar
Strange.are you sure the arm isnt bent and binding somehow? I still think you have way too much spring for the target boost you plan to run. However if the TS WG is like the one for my EFR you can mix and match springs so you should be able to make it work with the right combination of springs. That is assuming its not physically damaged.
Alternatively, I have an IX WG kicking around. PM me is interested...
Old Mar 14, 2019 | 06:45 PM
boostedwrx's Avatar
On ethanol? 30psi at 6k sounds good
Old Mar 14, 2019 | 06:54 PM
Fox_IX's Avatar
This was my first thought as well, what seems to be the issue?
Old Mar 14, 2019 | 07:47 PM
blackline's Avatar
5 Year Member
You can hear it leaking when applying pressure. Once I get it warrantied and still doesn't work correctly I'll PM you
I'm trying to you reach you numbers with the BBK
Not yet, tuning the 93oct map first then the e85...but it will live on ethanol after the tune is done.
