2006EvoIXer
close
- Join DateJul 2012
- LocationCalifornia
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:197 Times in 185 Posts
Pull it off and add grease. Make sure it does pivot to keep tension. Also, rotate your crank slightly to see if #1 piston goes up or down. If down, then it's 180° off to TDC, so take that into account if you want to set timing at TDC (you will be off by 180°. Lol
Quote:
Well, if the timing mark lines up it's correct no matter what right? Originally Posted by 2006EvoIXer
Quote:
Yup. Won't rotate or come off. Even gently put a pry bar on thereOriginally Posted by hutch959
with the auto tensioner off, the tentioner arm wont come off?
2006EvoIXer
close
- Join DateJul 2012
Correct. If all the timing marks line up, you are good.Originally Posted by CeliOnce
Well, if the timing mark lines up it's correct no matter what right?Yup. Won't rotate or come off. Even gently put a pry bar on there
As for the tensioner arm, you need to get it free so it can pivot. Is the bolt rusted so bad that it's frozen? Will bolt break if you try to break the bolt loose?
The bolt came off with no trouble but the arm was stuck.Thankfully after some PB blaster and wiggling I was able to get it off. Everything else came off smoothly and after a little break I'll be putting everything back together, with a generous dose of grease on the pivot arm. Any suggestions on type of grease? Is anti-seize not appropriate for this?
Biggiesacks
close
- Join DateAug 2005
- LocationWest Coast
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:708 Times in 595 Posts
Quote:
They need to line up, and the oil pump driven balance shaft needs to be in phase with the engine.Originally Posted by CeliOnce
2006EvoIXer
close
- Join DateJul 2012
Quote:
Oh yes, I forgot. Oil sprocket timing mark has to be in correct phase.Originally Posted by Biggiesacks
2006EvoIXer
close
- Join DateJul 2012
Quote:
I think any grease will work since it won't be hot like exhaust manifold where I use Never Seize grease.Originally Posted by CeliOnce
2006EvoIXer
close
- Join DateJul 2012
Looks like you are well on your way to fixing your timing belt problem. Good job catching in time! Most people would have driven until engine stops running after bendind some valves.
Yup, knew about the balance shaft phasing. Wanted to make sure about the crank
Quote:
Well I tend to be on the careful side after spending thousands of dollars and dozens of hours rebuilding the engine :P I'll definitely be rechecking the timing belt tension every oil change from here on out though. I wonder if the fact that I don't have my upper timing cover on (due to 4g64 block) led to the issue with the arm seizing (due to water). Or perhaps I overtorqued the bolt last time or didn't use enough grease, etc.Originally Posted by 2006EvoIXer
Yeah, could be, especially if you drove through some salty snow sludge and then left the car unused for awhile. With the arm freed and lubricated, the most important thing is having the belt adjusted to where the grenade pin is free in the tensioner as in the video. That assures plenty of take-up for any belt stretch. Originally Posted by CeliOnce
Yup, knew about the balance shaft phasing. Wanted to make sure about the crankWell I tend to be on the careful side after spending thousands of dollars and dozens of hours rebuilding the engine :P I'll definitely be rechecking the timing belt tension every oil change from here on out though. I wonder if the fact that I don't have my upper timing cover on (due to 4g64 block) led to the issue with the arm seizing (due to water). Or perhaps I overtorqued the bolt last time or didn't use enough grease, etc.
