Piston ring problem
Old Apr 27, 2019 | 06:00 AM
  #31
KingTal0n's Avatar
Originally Posted by Pal215
I was not aware that any none exotic oem engine could support 1000rwhp.
Really? and I thought sloppy was world famous
Allow me to introduce you then,
That is an OEM bottom end 6.0L engine making 1000rwhp.
Those motors (iron truck blocks) come in 4.8/5.3/6.0L sizes, cost roughly $300-$2000 depending on the version, and support from 600-1000rwhp roughly regardless of which version you use.
The 6.0 handles a bit more of course. The 4.8 though seems comfortable around 600rwhp (750bhp).
Its been done since 2002~ people using those engines in turbo applications for so long its become "cookie cutter"
If you need/want more info I got tons more videos and build threads. The idea here is we are using $300 engines to make ~750hp for example, and the motors last 10~ years at that level, very reliable. And being all stock with no machine work means no down time, no waiting, just plug and play.
Old Apr 27, 2019 | 02:26 PM
  #32
Pal215's Avatar
https://www.youtube.com/watch?v=ckALwOQKE2M
That is insane! Looks like I will need to look into these 6.0L blocks. Makes me want to use one for a future custom build.
Old Apr 27, 2019 | 07:38 PM
  #33
vincent.semesta's Avatar
"The idea here is we are using $300 engines to make ~750hp for example, and the motors last 10~ years at that level, very reliable. And being all stock with no machine work means no down time, no waiting, just plug and play"
6.0L, Mantul / Superb!!
Bigger than container trailer engine down here.
