Unable to shift 6th gear ct9a evo 8 mr
Old Jul 7, 2019 | 07:29 AM
gIGoN's Avatar
Guys. Having this problem since last night. Unable to shift to 6th gear. My shifter cables are good so i opened up the gear consol and noticed this piece im pointing at connected to the gear lever.
1. Should there be a rubber bush which connects to the lever?
2. How do i adjust this as i noticed theres a screw. If i pull the canle by hand just a tiny bit the 6th gear is engaged. I need to be able to tighten this so there is no free play between the gear lever which connects to this plastic thing.
Old Jul 7, 2019 | 09:37 AM
Well, for sure that plastic shift linkage end can not be sloppy around the post. If it is, it must be missing the bush
I think the part no. for the complete cable is MR580533 (double check part no.)
@gIGoN
Old Jul 7, 2019 | 10:14 AM
gIGoN's Avatar
Managed to stiffen up the linkage. However it still would not engage 6th gear. The symptoms before this was the 6th gear feels gummy when i want to release it. Only yesterday it couldnt engage at all. Other symptoms would be hard to engage gears during high revs say around 6-8k.
Now that ive put a bush to stiffen it and when i sort of force it into 6th gear it goes into the reverse gear. Luckily i tried it when i was in stationery. What else would seem to be the cause though.
Old Jul 7, 2019 | 01:48 PM
Hoping its not a trans synchro issue? After all, the 6 speeds tend to have a bit weaker synchro than the 5 speeds from what has been reported
Old Jul 7, 2019 | 08:05 PM
gIGoN's Avatar
If its the 6th gear syncro, can the replacement parts be purchased separately? Is the replacement straightforward if i were to take out the gearbox casing
Old Jul 8, 2019 | 06:02 AM
From my chair i would leave the trans work to the Pros, but there are some & you maybe one that can do a rebuild?
Dont think you would just replace the 6th gear synchro. You would likely have them all replaced at the same time
Old Jul 9, 2019 | 01:41 AM
gIGoN's Avatar
If i were to get the 5 gear gb from evo 7/8, it should be plug n play right? What about the shifter cable, does it need to be replaced?
