Timing belt bearings
Old Oct 9, 2019 | 09:34 PM
SimonE7's Avatar
Hello Everyone,
I have recently replaced timing belt, shaft balance belt, water pump, oil seals and 3 bearings.
Upon completion of the above, I noticed that there is an unusual sound from the timing belt area.
Could the sound result from incorrect bearings that were installed ?
please share your thoughts.
All advise will be greatly appreciated.
Regards,
Simon
Old Oct 10, 2019 | 07:28 AM
SoSoEVO's Avatar
Originally Posted by SimonE7
Hello Everyone,
Regards,
Simon
Have you replaced this updated bracket? https://www.evolutionm.net/forums/ev...elt-video.html
Old Oct 10, 2019 | 09:59 AM
barneyb's Avatar
The three bearings you refer to most likely are contained in the three pulleys that are normally part of a timing belt job. New bearings don't make noise.
Two things are critical when replacing the timing belts, belt tension and balance shaft timing. If either are wrong it could cause noise or vibration. Best to get it inspected by a knowledgeable person.
Old Oct 10, 2019 | 10:50 PM
SimonE7's Avatar
Hello SoSoEVO
Bracket was not replaced.
I suspect the unusual sound is from the bearings that were incorrect, appeared same as previous bearing but I guess the serial numbers are different
Old Oct 10, 2019 | 10:52 PM
SimonE7's Avatar
Well noted barneyb,
will have the tech check belt tension and balance shaft timing this weekend. hope to resolve
Old Feb 19, 2020 | 10:00 PM
UltimateZelda's Avatar
Did you find a resolution?
RussellM
22
Jul 26, 2025 09:02 AM
RussellM
MitsubishiParts.net - WA
Apr 1, 2014 10:22 AM
lbwilliams44
Sep 20, 2013 03:32 PM
