Help with p0171/p134 codes
Old Nov 3, 2019 | 05:57 AM
timmycat's Avatar
To start with had the car tuned on e85 at boosting performance in Illinois a few months after moved down to Florida after 2 or 3 drives the car started throwing p0171 bank one lean change out the front o2 sensor then got code p0134 bank one inactive. Replaced with the original o2 sensor still getting code p0134. Checked ground check Voltage check both fuse number 8s no vacuum leaks no exhaust leaks no boost leaks. 40 psi on fuel pressure. I'm at a lost. Is there anything I'm missing. Or could it just be as simple at a new tune due to the climate change the car is in.
Old Nov 3, 2019 | 01:53 PM
V.8MR's Avatar
Could it be a bad batch of E85 or that its now winter blend and has more gasoline in it? I also have an E85 map from Boostin and moved to Missouri ha. But still running on a tank of summer E85 as the car does not drive much. Do you have an AFR gauge? Or can you test the fuel?
You may want to call Boostin when you can. I find they are fairly responsive when I need them.
timmycat
Nov 2, 2019 07:00 PM
Jp7
E85 / Ethanol
64
Nov 27, 2017 12:07 PM
Hotsauce101
Aug 26, 2016 02:42 PM
SmurfZilla
E85 / Ethanol
Oct 26, 2009 05:35 PM
rEVoLed
E85 / Ethanol
11
Mar 13, 2009 01:58 AM
