P0134/P0171 code help.
Old Nov 2, 2019 | 07:00 PM
timmycat's Avatar
To start with had the car tuned on e85 at boosting performance in Illinois a few months after moved down to Florida after 2 or 3 drives the car started throwing p0171 bank one lean change out the front o2 sensor then got code p0134 bank one inactive. Replaced with the original o2 sensor still getting code p0134. Checked ground check Voltage check both fuse number 8s no vacuum leaks no exhaust leaks no boost leaks. 40 psi on fuel pressure. I'm at a lost. Is there anything I'm missing. Or could it just be as simple at a new tune due to the climate change the car is in.
alexc
Mar 21, 2017 10:07 AM
smokehim98
Jan 18, 2012 09:47 AM
TEAM ACE
Jun 17, 2009 06:43 AM
monkeyevo
Feb 20, 2009 02:47 AM
bagice
Lancer Engine Tech
Dec 20, 2006 11:42 AM
