Oil pressure sensor location/type
Hi everybody where do you put your oil pressure sensor ?
is there an replacement for the oem pressure switch ?
currently running a haltech ecu and want the failsafe function enabled.
Car is an evo ix
Thank you
Car is an evo ix
Thank you
^Same as above, except I used an AMS relocation line (pretty sure it's the same). Highly recommend using either one of the lines (STM or AMS) as the sensor will break in the housing over time due to vibration
