Evo 8 Overbore
Old Apr 14, 2020 | 11:23 AM
blackline's Avatar
5 Year Member
Evo 8 Overbore
What are the power limits of a 2.0l 4G63 with the cylinders bored to .030 or .040?
Old Apr 14, 2020 | 03:51 PM
CurseDSM's Avatar
Why so deep on the overbore? Normally its .20 over unless it has been done already then .30 to .40. But to answer your question I had my talon with a .40 overbore being it was done and need to be redone and I made well over 500 to the wheels.
Old Apr 15, 2020 | 06:24 AM
blackline's Avatar
5 Year Member
The block is currently at .020, thanks for the input
Old Apr 15, 2020 | 07:42 AM
CurseDSM's Avatar
Ok if that is the case then depending on what the cylinders look like have it rehoned and call it a day. If the cross hatching is still good or looks good your machinist will let let you know or you can ask him which would be the best to do. In my case my stuff needed to be redone the cross hatching was gone someone forgot to put oil squirters in and it ruined the walls pretty bad. Was an expensive oops lol
Old Apr 15, 2020 | 08:15 AM
LetsGetThisDone's Avatar
Oil squirters aren't there to oil the cylinder wall. They're to cool the piston, but forged pistons don't need them. You had other issues or just simply wore out.
Old Apr 15, 2020 | 08:24 AM
CurseDSM's Avatar
I am aware of that but the car at the time had squirters, and I never plugged the holes so it just drained. Idk if it was a ring issue or what but **** got ****ed up and had to redo everything it was tore up pretty bad. No oil to the head or turbo being it was head fed.
Old Apr 15, 2020 | 08:43 AM
blackline's Avatar
5 Year Member
Thanks, waiting on a drop off date for the machine shop and just trying to plan for the worst case.
Old Apr 15, 2020 | 08:49 AM
CurseDSM's Avatar
Walls don't look to bad really. Maybe just another hone depending on how deep those scratches are on the cylinder walls are again I would talk to the machine shop and see what they recommend.
Old Apr 15, 2020 | 09:12 AM
barneyb's Avatar
Forged pistons may not need the cooling, but notice many of the newly designed engines have oil squirters. Oil squirters help control knock.
Old Apr 15, 2020 | 03:39 PM
If you left the oil squirter ports just open (no plug/bolt or squirter), the poor thing would have had zero oil pressure.
Old Apr 15, 2020 | 03:42 PM
Ford put them in the new 5.0 in 2011, then removed them in 2013. They don't control knock, and they're not needed in an Evo engine when moving to aftermarket forged pistons. Most of the pistons don't even clear the squirter anyways, and when you bend it to clear the skirt, it's not even hitting the part of the piston that needs cool and they end up just breaking off.
Old Apr 15, 2020 | 04:13 PM
Biggiesacks's Avatar
The 5.0 is N/A though, what about the ecoboost engines? By not needed are you talking about engines that only see short bursts of power (Drag racing / highway queens) or are you also including engines that see extended operation at high boost (track cars)?
Old Apr 15, 2020 | 04:17 PM
CurseDSM's Avatar
Yep I am guilty. I didn't realize that they were not plugged, put the oil pan on thinking they were blocked off got it together in the car car fired right up and then churp churp churp aww wtf.
Old Apr 15, 2020 | 04:39 PM
I'm talking about all them.
They are simply no needed with an appropriately engineered forged piston, and for the reasons I already listed they don't even work with most aftermarket pistons.
Old Apr 15, 2020 | 04:40 PM
That's completely different from plugging them lol. But damn man that had to have sucked wiping out a fresh build in 30 seconds on the first start up.
