Compression opinions?
Old Aug 19, 2020 | 09:38 AM
  #31
Abacus's Avatar
Originally Posted by mazdabish
What are "the best" pistons on the market for these cars for anything other than power? I have reasonable goals of 500-600whp which realistically any piston can handle, just not sure given the amount of options so more aiming towards consistency/quality/easiest to build, quietness, least oil consumption, etc (pretty much anything other than power I guess). All below are 2618 forging. Does not help my machinist has no preference lol. He's used everything apparently.
Do the piston weights matter?
Wiseco 1400HDs K626M86AP? 349g avg weight, cheapest/most common, proven option I guess.
https://www.extremepsi.com/store/Wis...II-and-IX.html
JE FSRs? 309g avg weight, cheapest. There's also JE Ultras but they're 10.0:1 comp and probably not off the shelf.
https://www.extremepsi.com/store/JE-...II-and-IX.html
Diamond 82005-4? 356g avg weight and has gas ports, moly coated skirts, and "forced pin oilers from the oil ring". 3-4 week order time (all custom not off the shelf). Had these in my motor and were okay.
https://www.realstreetperformance.co...-3cc-9-11.html
Manley Extreme (345g) or Turbo Tuff (375g) Pistons? Thickest wrist pins on the Turbo Tuffs @ .250in but also heaviest. Has gas ports on the Turbo Tuffs, all off the shelf (TurboTuff might be harder to get).
https://www.realstreetperformance.co...06310ce-4.html
https://www.realstreetperformance.co...-stroke-2.html
For moderate levels any of those pistons are fine. It is nice to have a strong pin .230 or. 250 IMO since these engines are run hard. Gas ports may help ring seal as well. There are DLC coated pins and stronger .200 wall pins out there too.
I'd be more concerned about saving Rod weight and would go into a Carrillo rod for its weight and strength. Less weight is easier on the bearings.
I'm running a custom CP/carrillo package in both cars and it works well.
Old Aug 19, 2020 | 02:07 PM
  #32
mazdabish's Avatar
I'm reusing my Manley Turbo Tuff 150mm I beams w/ARP 625+ Rod Bolts and 88mm Crank. The Carillo Rods at 567g (vs 675g of the Turbo Tuffs) would be tempting if my rods were done but I'm 99% sure they're serviceable as the car didn't spin a rod bearing.
Wisecos, JE FSRs and Manleys don't have gas ports, only the Manley Turbo Tuff Pistons and Diamonds have gas ports but both look like custom order affairs (plus the Turbo Tuff Pistons are the heaviest piston...roughly 25g heavier than the Diamonds I had in my old motor). The CPs have a .180 pin which seems a bit weak, don't think the JE is worth considering for the .150 pin too.
Have a feeling it'll come down to the Wisecos or Manley Extremes, I'll ask my machinist. A lot of his builds use Wisecos but he has experience w/everything.
Old Aug 19, 2020 | 02:38 PM
  #33
LetsGetThisDone's Avatar
Sell the manley's for 5-600 and get the Carrillo's. Weight matters and your rod bearings will thank you.
Old Aug 19, 2020 | 03:41 PM
  #34
blackline's Avatar
5 Year Member
Imagine running an Evo at 7psi and being wildly disappointed the entire ****ing time.
LOL
Old Aug 20, 2020 | 04:09 PM
  #35
Gtimportfanatic's Avatar
5 Year Member
I thank you all for your inputs, i had an idea of what I needed to do but this just confirms what needs to happen.
Old Aug 21, 2020 | 02:57 PM
  #36
CurseDSM's Avatar
*cough cough* 12.5:1 e85 all the time and a lame pump gas tune to get you to an e85 station or lower boost with minimal timing *cough cough*
Old Aug 22, 2020 | 08:26 AM
  #37
Abacus's Avatar
Its an old 80's engine not a K series.
Old Aug 22, 2020 | 09:05 AM
  #38
CurseDSM's Avatar
That shouldn't matter if its old or new hell I've seen tons of old **** put on e85 with a way to tune it and made good power. My gf stepfather has a 71 charger and challenger both with original engines one is fuel injected and the other he just bought but the challenger has fuel injection on the original engine and it makes 700 wheel all day long with its mods and e85. So I don't buy that one bit.
Old Aug 22, 2020 | 09:54 AM
  #39
RS200's Avatar
No, as in an Evo is going to run like trash at 12.5:1 compression on pump gas, even without boost. We don't have the cylinder head to get away with that. Your gf's friend's stepfather's uncle isn't running 12.5:1 on his Mopars on pump gas either. At 10.5:1 with a tune to limp on low ethanol, maybe, but it's not going to be pleasant. I'd much rather sacrifice that last bit of power from compression to be able to run a mean tune on pump gas and not have to worry about it blowing up.
Old Aug 22, 2020 | 01:57 PM
  #40
Abacus's Avatar
May want to do some research on compression and tuning . Every fuel, engine and setup has its limits.
Ask yourself this question.
If more compression was the answer don’t you think more people would run it on these cars.
Keeping the headgasket ,rod bearings and valves intact would be a challenge .
Old Aug 22, 2020 | 02:53 PM
  #41
CurseDSM's Avatar
My car ran fine before I put the new setup on it, and yes my motor is a 2.4 with 12.5:1 and even with the **** tune that was in it, it ran like a top. Now I can't get it to start and I haven't found the reason why yet. Sometimes I wish I would have just left it alone
Old Aug 22, 2020 | 03:04 PM
  #42
Biggiesacks's Avatar
Well an engine with that much compression usually requires some domed pistons (AFAIK). With that kind of setup piston to valve clearance is pretty critical, so if I was you I would probably do a compression and leak down test to make sure its still sealing up ok.
Old Aug 22, 2020 | 03:06 PM
  #43
CurseDSM's Avatar
For one I didn'r say my gfs stepdad ran 12.5:1 in his Mopar I said he runs e85. My car runs fine on pump gas even at 22 psi with 12.5:1. Yeah sure timing is a little low but its wastegate pressure only but its still 22 psi and still made good power (439/418 to be exact on a mustang dyno at that) on a turbo similar to a black on a 2.4 with that compression. So with that said it can be done.
Old Aug 22, 2020 | 03:10 PM
  #44
CurseDSM's Avatar
I did compression test last week being i washed the cylinders and i was still in the 200s after wetting the cylinders after changing the oil.
Old Aug 23, 2020 | 11:01 AM
  #45
RS200's Avatar
Does anyone even make a 12.5:1 piston for the 4G64?
