Evo 8 built motor. Head ticking? Lifters?
Hey guys i just started getting this tick about 100 miles ago. Thinking lifters?
posted a video let me know what you guys think! Thanks!
sounds very bad, I can say forsure it isn't a lifter tick. that sounds more like a rod knock. as mentioned check pan/filter for metal shards. Check main engine and rod bearing clearance.
sounds like you got a failed lifter.
i would pull cams, and pull out the lifters and check.
i wouldnt run it like that.
or at least pull off the valve cover and make sure everything looks ok
I could see that, a collapsed lifter would let the rocker arm flop around if it wasn't pumping up with oil. That would be a easy check pull valve cover and see if any of the lifters compress.
No damage inside the head from what i saw when i last checked. I bled the lifters And ticking went away slightly. Should of just changed them all when i was in there. Now at cold start there isnt any tick once it warms up it comes and goes then stays permanently. Now sounds like its not running on all 4
RuckerPark
Oct 21, 2009 11:03 AM
TTOPPOUZI
21
Dec 4, 2006 12:38 PM
