Built Motor?
Old Apr 3, 2010 | 09:03 PM
MitsuOZ's Avatar
Built Motor?
When I bought my car last year I had no idea of it's previous history, soon later to find out the motor was replaced under warranty 8k miles before i purchased, for some reason i feel like the bottom end was built though, is there any way to see without taking the head off or the motor apart? and my engine has a black coating on it, is that stock ?
Old Apr 3, 2010 | 11:31 PM
lemmysports2's Avatar
the block is painted black from the factory. pull you valve cover off, you can see what cams you have, if there are aftermarket head studs present, etc...
pull of you roil pan and see if the pistons are stock
Old Apr 4, 2010 | 07:17 PM
jy951's Avatar
Why do you think it was built? I would think it would be stock and the po blew the previous motor, got it replaced and then just unloaded the car. Maybe do a compression check?
Old Apr 4, 2010 | 07:19 PM
chaotichoax's Avatar
I feel like this is the silliest thing I ever heard
Old Apr 5, 2010 | 09:07 PM
MitsuOZ's Avatar
sorry i did not explain, the invoice from the Mitsubishi dealer that replaced the motor said that the warranty request put in by Devo tuning, and went back to them after they put in the new motor
Old Apr 5, 2010 | 09:40 PM
I'd agree with hotrod here...give devo a call can't hurt
Old Apr 5, 2010 | 09:45 PM
RockmanX's Avatar
agreeed give them a call and find out yourself
Old Oct 21, 2020 | 10:26 AM
leecavturbo's Avatar
odd
Daily Nate
Jan 7, 2019 04:20 PM
hispanicpanic
Aug 20, 2014 05:35 PM
stck_trbo_mnstr
25
Mar 31, 2011 08:13 AM
EidolaDream
Automotosports - Illinois
Jun 29, 2005 04:06 AM
