Anti surge on an fp turbo how much power does it add
Its' purpose is to help reduce surge and has nothing to do with increasing power. Surge occurs when the turbo is putting out more air vs what the engine can ingest so the air backs up on the compressor wheel and causes surge, which is typically audible and can cause the car to buck.
The FAP cover does increase flow, but its more so when the compressor is approaching or at the choke line. You won't notice at low boost.
The surge 240Z is talking about generally occurs during spool up, especially in higher gears. So the FAP cover may help a bit there.
e4on2e5
13
Dec 31, 2010 03:29 AM
