Exedy Twin Disc weird noise(not rattle)
Old Dec 28, 2020 | 01:08 AM
TME_4g63's Avatar
Hello everyone. New member here.
Installed brand new exedy twin disc in my 5spd. I understand twin discs have a rattle when clutch pedal is pressed. However, there’s another weird noise coming when I blip the throttle or shifting from one gear to another.
Scenario:
Car in neutral, clutch pedal not pressed, blip the throttle: No abnormal noise
Car in neutral, clutch pedal pressed fully, blip the throttle: Abnormal noise
Attaching a vdo. First 4 throttle blips, clutch pedal is not pressed(for noise comparison sake).
Please guide for troubleshooting. The clutch has only 150km granny driving on it.
Old Dec 28, 2020 | 01:17 AM
TME_4g63's Avatar
At times, it’s difficult to shift to 1st gear as well. I gotta try 3-4 times before shifter finally engages to 1st
Old Dec 28, 2020 | 02:54 PM
CurseDSM's Avatar
I didnt watch the vid but if your having issues shifting out of first gear, then you need to adjust the clutch pedal.
Old Dec 29, 2020 | 12:02 AM
TME_4g63's Avatar
no it’s shifting in to first from neutral which takes couple of tries.
Old Dec 29, 2020 | 12:19 AM
Evo9_Dubai's Avatar
This sound is not bhot acha !!!!! I would definitely remove the tranny and inspect.
Old Dec 29, 2020 | 07:56 AM
CurseDSM's Avatar
After watching the video yeah it sounds like it is dragging which means and adjustment is needed. It should have no issues going into first gear at all. Before you start taking things apart turn your clutch adjustment on your clutch pedal counter clockwise a turn and see if it helps. If you put this car back together without any adjustment what so ever that is your problem. You have to readjust the clutch to compensate for the new discs.
mr evo7
Jul 24, 2014 05:24 AM
mr.almeida
Mar 29, 2010 05:38 PM
v8slayer07
Jun 22, 2008 07:03 PM
TonyG
16
Jun 28, 2006 07:46 PM
evosevengsr
May 20, 2004 01:51 AM
