EVO 6: Factory Bearing Sizing
Old Mar 26, 2021 | 01:20 PM
Tim M's Avatar
5 Year Member
Greetings.
We are working out the bearing clearances for the mains and rods for an Evo 6. The crank is used, but polished. The rods are non-machined Oliver rods.
We installed S0 bearings in the case and rods and took the parts to a helpful machinist to measure exact numbers with his precision instruments:
Mains:
0.07 mm / 0.0028 in
Rods:
0.08-0.09 mm / 0.0031-0.0035
Based on forum researches, the preferred clearances are closer to 0.0020 - 0.0025...for a 400 HP street car.
Our question: what are the increments for the factory bearing offerings - S0, S1, S2, S3, and S4?
We've seen a reference to 0.0075 mm / 0.003 in between the rod bearings offerings, but not definitive.
Thanks for any inputs!
Old Mar 27, 2021 | 01:05 PM
Tim M's Avatar
5 Year Member
Tip from the forums pointed us toward the Evo 6 factory manual - thickness of the rod shells:
0 1.483 – 1.487
1 1.487 – 1.491
2 1.491 – 1.495
Which extrapolated, the thickness between 0 and 2 is 0.008 for each shell...since two = 0.016. This would decrease the rod bearing clearance to 0.074 which seems still on the high side, but below our threshold before going another direction.
The mains appear to be similar in sizing and can easily update to 0.0625 using the S1 bearing which is perfect, it would seem. Hate to buy another set of bearings, but closer to the target and much more confidence in spinning it to redline!
Thanks!
Adriank
Nov 16, 2020 11:37 AM
Dannievo
16
Apr 26, 2015 08:54 PM
bryonboals
Oct 3, 2014 08:47 AM
craigybaby37
Nov 23, 2011 05:13 AM
aps
Nov 15, 2005 01:03 PM
