Evo 8 - 5 speed shifter cables
Old Apr 19, 2021 | 06:33 PM
Mrgoozo's Avatar
Greetings all,
So i just got my evo 9 and while we were building the engine finishing the car i noticed that it has a 6 speed shifter cables installed on a 5 speed trans swap.
And unfortunately the 5 speed shifter cable is discontinued.
Would be any other was to fix this problem?
so now my shifter cables has 2 small bushings, which should have been 1 big and 1 small for the 5 speed.
I saw that the evo x later models has similar cables bushing but anyone can confirm if it works on the evo 8 trans?
Thanks
Old Apr 24, 2021 | 08:53 PM
Mrgoozo's Avatar
Pump for help, anyone?
Old Apr 25, 2021 | 09:46 PM
Ayoustin's Avatar
I'm not aware of any cables other than the factory cables that work with the 5 speed. I'm in the process of developing an aftermarket replacement set of cables for guys doing 5 speed swaps but it will be another month or two until I've completed the design.
Old Apr 26, 2021 | 01:47 PM
Mrgoozo's Avatar
Thats wonderful!
I dont mind waiting to be honest as i dont have any other option at this moment.
I hope you can keep us updated on that.
Old Apr 26, 2021 | 10:17 PM
Ayoustin's Avatar
I'll be sure to be posting about them when they're ready.
Old Feb 12, 2022 | 06:30 AM
VeebeeIX's Avatar
any update on these cables ?
I am looking for a new set for 5spd with the bushings.
Old Feb 13, 2022 | 10:44 AM
Ayoustin's Avatar
Still sorting things out with cable suppliers. Hoping to have it kicked off in the Spring.
Old Feb 14, 2022 | 05:25 AM
VeebeeIX's Avatar
found this yesterday and ordered from them.
https://www.evolutionracingspares.co...speed-mr581210
Old Mar 13, 2022 | 12:33 AM
VeebeeIX's Avatar
Now I'm abit lost.
I ordered these 5 speed shifter cables but both have the small end/bushes. But the part number on the packaging is for 5spd.
(MR581210)
My current one has 1 big and 1 small.
Now having spent 500odd AUD and shipping, customs etc. Can I use these cables or will it be a problem ?
Old May 25, 2022 | 11:48 AM
krys88's Avatar
Did you end up using those cables? I am about to order them. Please let me know. Thanks
Now I'm abit lost.
(MR581210)
Old May 25, 2022 | 11:55 AM
VeebeeIX's Avatar
I have installed them as yet, but I did ask a few shops and they say it can be used.
I might only them on this weekend if i get time.
Old May 25, 2022 | 12:05 PM
krys88's Avatar
Ok please let me know after you install it. I think you will need to use 2 small bushings instead of 1 big 1 small, if I am correct
Old May 25, 2022 | 12:07 PM
VeebeeIX's Avatar
Yes they do have the oem rubber bushings on , but i do have aluminum bushings to go on, both small.
Old May 25, 2022 | 12:47 PM
Ikuhara's Avatar
I had some of these on order recently but ended up cancelling it. I had seen a review where someone said that it didn't fit usdm evo so I backed out on it. Guess we'll see if Veebeel can give us confirmation whenever he tries.
Old May 25, 2022 | 02:44 PM
ihockey1's Avatar
I follow these guys on FB and they just released a set of cables if you wanna look them up
