Map sensor install jdm evo 8
Old May 27, 2021 | 03:37 AM
Ryu360's Avatar
Hey guys, needs bit of direction and/ help here, I’ve searched through already and just wanted a bit more clarification on this. So a s the title says I have a jdm evo 8 which did not come with a map sensor but my tuner and I want to run speed density. I bought the adapter from extremepsi and am using a Omni 4bar. I’m just wondering where would be the best place on the intake manifold to plumb into that would bit affect the readings on the map sensor. Thank you!
Old May 28, 2021 | 06:24 AM
justboosted02's Avatar
are you on the stock intake manifold or an aftermarket?
plumed somewhere into the plenum without a long vac tube should be fine.
Old May 28, 2021 | 06:32 AM
Biggiesacks's Avatar
If your manifold doesn't have the OEM map sensor port machined into it there isn't too much reason (Or ability) to use the omni. They are notorious for going bad. You can just use a more traditional map sensor and Tee it into boost line for the fuel pressure regulator (PRE SOLENOID). You will need to alter the wiring harness you have and change the map sensor scaling in your tune to match w/e sensor you choose but that's pretty trivial vs machining your manifold for that sensor.
Old Oct 11, 2021 | 06:48 PM
aqeelrizni's Avatar
Im in a similar situation. Can i know where you finally installed your map sensor?
Mine is a jdm VIII without a factory map...
Old Oct 22, 2021 | 08:30 PM
aqeelrizni's Avatar
Bump anyone?
Old Oct 29, 2021 | 05:03 PM
asugamilla's Avatar
Hi Guys,
all you need to do is "T" in a vacuum/boost line from one of the lines running off the JDM inlet manifold.
I chose one which sits behind the number 2 and 3 stock inlet runners and connected it to a GM 3bar map sensor which
is wired into the stock 3 pin ECU and is mounted on the firewall.
Pin 42 for 5v
Pin 46 for ground
Pin 92 for signal wire
If you are converting to SD, there is a SD harness which plugs into the MAF plug which connects to the AIT and the MAP to give
the ECU those inputs without hardwiring the MAP directly to the ECU as I did.
hope this helps.
Anth
Old Oct 30, 2021 | 02:07 AM
aqeelrizni's Avatar
Originally Posted by asugamilla
Hi Guys,
Pin 42 for 5v
Pin 46 for ground
hope this helps.
Anth
Thanks a lot Anthony, this certainly helps. Got my hands on an AEM 3.5 bar brass map sensor.
Im planning to go the SD route as well hopefully!
Abacus
Sep 16, 2014 02:05 PM
evodziobak
Jan 29, 2009 09:23 AM
Mike01gsr
MitsubishiParts.net - WA
13
Oct 14, 2008 08:46 AM
STIKILLA1084
Aug 10, 2008 08:22 AM
