Spark Plugs
Old Apr 15, 2004 | 09:10 PM
evosevengsr's Avatar
Question Spark Plugs
what plugs would work great on the evo?
I'm looking to run 9's for everyday driving and use 11's for racing.
someone was telling me something about resistors or something.that the plugs have to be resistor type etc...
what plugs are u guys using?
if anyone is using 9's, which ones are they?
thanks.
Old Apr 15, 2004 | 11:03 PM
EvolvedDSM's Avatar
Are you talking heat ranges? If so, those sound a bit extreme. USDM stock heat range is 7 and (using NGK's scale), two steps colder for daily driving would almost certainly foul. I'd stick with the stock heat range for 20 PSI (1.4 bar) or less and step up to an 8 (maybe a 9) if you're running higher levels.
Old Apr 15, 2004 | 11:08 PM
evorent's Avatar
ngk BP9EGV for road and racing
Old Apr 15, 2004 | 11:24 PM
1QWKEVO's Avatar
man 7's are cold enough... the only reason i'd drop to 8's is if i were to get on the bottle with boost or run a stupid amount of boost... to get 7's to run hot is going to take alot ...
Old Apr 16, 2004 | 12:37 AM
1StockEvo's Avatar
ngk bpr7eis are a step colder for the evo right?
Old Apr 16, 2004 | 01:08 AM
1QWKEVO's Avatar
7's are stock, with 19psi the car comes a step colder with a small gap ... traditional DSM plugs are 6's with .44 gap
Old Apr 16, 2004 | 01:27 AM
EvolvedDSM's Avatar
NT DSMs were gapped to .044, but turbo models have the same spec as the EVO: .028-.031. The BPR7ES would be the copper equivalent of the OEM iridium plug.
Old Apr 16, 2004 | 02:10 AM
1QWKEVO's Avatar
actually the turbo model had those funky @$$ plugs i never did check the gap but i could swear it was .44
update: I stand corrected the gap was .32 .... sorry guys!
Old Apr 18, 2004 | 06:44 AM
thing is....I am on the bottle.
I think I read that you should inc. by 2 points for every 50hp shot or something like that.
but thanks for the advice...i think i'd use the 7's for daily driving.
btw....what about the resistor thing?
Old Apr 18, 2004 | 06:59 AM
Grod101's Avatar
Do Not gap it at .44 are you nuts....where are you getting these numbers
The gap should be at .28............. even stock it about .32 but .28 it the over all best.... and that comes from Jeff Hill who is a top tuner in the 4G63 world
Old Apr 18, 2004 | 07:33 AM
nothere's Avatar
resistor (R) plugs are needed, without them the radio will be another monitor of engine rpm. might mess with the ecu too?
Old Apr 18, 2004 | 07:38 AM
Grod101's Avatar
Just use NGK plugs... that is all you need and gap them what I stated above
Old Apr 18, 2004 | 04:32 PM
thanks man
Old Apr 18, 2004 | 04:34 PM
evo81's Avatar
can you tell any diffrents with them?i was thinking about getting those also.
Old Apr 18, 2004 | 06:44 PM
Porsche518's Avatar
is there any link that explains spark plug temps? Im fairly new to it and this heat index you guys are talking about is alien to me.
