boost solenoid/FPR vacuum line question
Old Jan 17, 2022 | 07:25 PM
raverthug's Avatar
Im mounting my boost controller and Fuel pressure regulator on a bracket next to each other. Can I run 1 line in and T it to each or does the FPR need its own dedicated vacuum line to avoid fluctuations?
Old Jan 18, 2022 | 05:49 AM
schuhie's Avatar
Generally, they should get their own lines but because of where each should be sourced.
You should source the boost controller line pre-throttle body and the FPR should be sourced post-throttle body(intake manifold).
Old Jan 18, 2022 | 04:21 PM
hutch959's Avatar
^^ this is correct...
Old Jan 18, 2022 | 06:10 PM
raverthug's Avatar
Perfect. Thank you
Old Jan 28, 2022 | 06:33 AM
tunermt's Avatar
This is correct: Wastegates are intended to only see boost pressure, vacuum can damage the diaphragm in a wastegate.
fpr on the other hand needs to reference manifold pressure (vacuum and boost).
Old Jan 28, 2022 | 09:36 AM
240Z TwinTurbo's Avatar
It is advisable to keep pressure references separate when possible, but running the boost controller and FPR off a single line will not affect anything.
Old Jan 28, 2022 | 12:09 PM
LetsGetThisDone's Avatar
I would not reference boost control from a post-throttle body source. You will lose boost pressure, closing the gates, before the turbo looses drive pressure. Not a good scenario.
Old Jan 28, 2022 | 05:37 PM
it depends on whether he is referring to the solenoid or an actual boost controller. Boost controllers reference boost from the intake manifold, but the solenoid references pre TB. My boost controller (profec B) tee’s off the FPR line with zero issues. My gtr references boost control from the intake manifold just the same as the EVO.
Ralph
Sep 10, 2011 05:38 AM
F0RSAKEN
Aug 10, 2010 11:37 PM
boostedawd
Apr 27, 2008 05:33 AM
