Cracked Head?
Old May 4, 2022 | 12:11 AM
gIGoN's Avatar
Cracked Head?
Took off my head and sent it for resurfacing right away due to water leaked into the piston which i assumed from a lifted head. When i got the head back noticed there is something which looks like a crack. Please see the pic. Does this mean this head is gone and i need a new one?
Old May 4, 2022 | 07:40 PM
Certainly looks like you need to have the head inspected by the machine shop. Penetrating dye may be used to confirm if that is a crack
That pic certainly look suspicious & its right over where it mates to the cylinder bore
Thats how i see it anyways. Keep us posted please
Old May 4, 2022 | 10:02 PM
Evov10's Avatar
That's corrosion not a crack. Not sure if it needs to be resurfaced though.
Old May 4, 2022 | 11:33 PM
gIGoN's Avatar
it was just resurfaced. that's when i noticed it after those carbons are no longer there. i can actually feel it when i run through my nails over it that there's some sort of crack, and yes its right where it mates the cylinder bore.
Old May 5, 2022 | 05:18 AM
Was going to ask you about the finger nail test. A good machine shop should be familiar w/crack testing aluminum. One would have thought the folks that did the resurfacing would have seen that?
Did you consider asking them about this issue?
Old May 5, 2022 | 07:22 AM
RallySport9's Avatar
Exactly my thought, what kind of machine shop resurfaces a head and doesn't mention a crack!
Old May 6, 2022 | 04:47 PM
wizzo 8's Avatar
If it is a crack then they should be able to weld it up and resurface it.
juanraulgarcia
Sep 29, 2014 06:34 PM
Johnboy1065
May 25, 2008 03:41 PM
