Late Model 4G63 swap into 1990 Galant VR-4
Old Sep 11, 2022 | 09:40 AM
sleepijiji's Avatar
Hello,
I have an old 90s Galant with a 4G63 and it has quite a fair amount of miles on it. At some point I will probably need to put in a new motor and gearbox as I do not plan to sell this car. Is it possible to put an Evo 8/9 4G63 and the 6 speed into my Galant?
I’ve not seen any posts about this swap being done, but are the dimensions different or would this swap be in any way difficult? Firstly for just the straight engine swap and secondly for a gearbox swap from my current 5 speed to the Evo 9 6 speed.
Many thanks!
Old Sep 11, 2022 | 04:13 PM
eliruiz's Avatar
Gonna need wire harness, ecu, and then gonna have to do some fab work to mount the engine and transmission
Old Sep 12, 2022 | 02:16 PM
V.8MR's Avatar
The timing cover is on the other side as well as the trans. Would need a Custom subframe. Maybe Racefab in NZ has a solution. I know they have a kit to mount later model Evo (4+) into the Evo 1-3 which has the DSM style drivetrain/motor layout.
Old Sep 12, 2022 | 08:38 PM
RS200's Avatar
New subframe, N/S bar, custom front axles, custom exhaust, cutting the rails for transmission clearance, welding mounts to the chassis, intercooler piping, redoing the whole wiring harness, battery placement, new driveshaft, finding a rear diff ratio that will work, and on and on and on. It's adding 10x the complexity to what is really a simple problem. Rebuild your 6-bolt 4G63.
LSs1Power
May 27, 2017 09:17 AM
xXlEVOlXx
May 21, 2012 01:39 PM
SleepySamurai13
21
Apr 28, 2009 10:43 PM
rEvolution420
May 13, 2007 09:18 PM
andy_1985
Lancer Tranny/Drivetrain Tech
25
Nov 19, 2005 07:32 AM
