What kind of Power steering fluid to add?
Old Apr 18, 2004 | 02:49 PM
memo3's Avatar
I was hearing weird sounds for couple weeks. At first, I didn't mind but then this morning I checked the power steering fluid and it was little low so i thought that might be why.
What kind of steering fluid to add?
Does it have to be the same that dealer used before?
I have STP Power steering fluid sitting in my house. Do you think that will work? Btw, how many quarters does the car take at max?
Thanks in advance
Memo
Old Apr 18, 2004 | 02:59 PM
Grod101's Avatar
go to the dealer they will fill it up for you... It is a closed system it should not be leaking... if it is have them fix it for free...
Old Apr 18, 2004 | 03:10 PM
memo3's Avatar
It probably leaked from somewhere when they were installing some of my stuff...
I am scared to take it to the dealer because I have turbo upgrade etc.
Old Apr 18, 2004 | 06:03 PM
jemm's Avatar
Go to your dealer's part's department and ask for Mitsubishi Genuine Power steering fluid . Some times the Evos come from the factory with it not filled properly. If the levels drop again.. do what Grod101 says and take it to the dealer for leak inspection.
are you seeing any redish fluid in / on your driveway?
down here we use the Mitsu ATF-spiii, but you should use what your usdm manual tells ya :
Attached Thumbnails What kind of Power steering fluid to add?-mitsupwrstf.gif
fujirio
Outlander Sport
Dec 26, 2016 10:31 PM
k0lok0yboi
13
Apr 18, 2016 02:08 PM
bluebanana23
15
Jan 5, 2016 12:27 PM
xLancer_Beastx
Sep 12, 2010 12:59 PM
memo3
Jun 11, 2003 11:08 PM
