engine ticking under 1krpm
Old Mar 26, 2025 | 04:05 AM
turbo R's Avatar
i own a 2005 airtrek turbo r pretty much the same engine as the evos and before the ticking sound started there was a whining noise under 1000 rpm and i thought that it was just a belt but then it started ticking and low oil pressure light came on but the car only ticks and shows low oil pressure under 1k rpm what could this be? is my engine ****ed? also sorry if my grammar sucks english is my third language
Old Mar 26, 2025 | 10:11 AM
ViciousLSD's Avatar
hydraulic lifters probably? theyre cheap and easy to replace. it definitely made mine quiet. i use Topline, bought from ETS
Old Mar 26, 2025 | 10:51 AM
schuhie's Avatar
Sounds like you might have low oil pressure? I would suggest a manual gauge to check it. That ticking could be lifters because of low oil pressure to the head.
I had the low pressure light turn on but was able to verify with my manual gauge that oil pressure was fine and it was just the sensor.
Get a pressure reading with the car warm and report back.
Old Mar 28, 2025 | 08:43 AM
turbo R's Avatar
ok will do is there anything else that can cause knocking sound under very low loads also the engine was struggling to idle when i came to a stop it would drop down to 500rpm and almost shut off
Old Mar 28, 2025 | 11:32 AM
schuhie's Avatar
Hard to say, I would focus on 1 issue at a time. Check the oil pressure and see what that looks like. If its bad, the rest of it doesn't really matter that much bc it needs a rebuild anyways.
I had the low idle issue with my car for a while and finally got it fixed replacing the MAP sensor. Are you running a stock or aftermarket MAP; and if aftermarket, which one? The onmi's are known to be weird from time to time.
Old Mar 28, 2025 | 11:33 AM
schuhie's Avatar
Those Toplines working well? My car has had a lifter tick from the day I got it basically. I'm on my second head and 3rd set of lifters; 1 OE and 2 GSC "No"-Ticks lol.
I keep seeing people talking about these, maybe its time I finally grab a set lol.
Old Mar 28, 2025 | 11:47 AM
turbo R's Avatar
ok ill check the oil pressure tomorrow and report back
Old Mar 28, 2025 | 02:15 PM
ViciousLSD's Avatar
oh yes. i've bought them 3x because I didnt want to clean them after spun bearings, and theyre 100% no ticks everytime. but i havent had the chance to give them lots of mileage
Old Mar 28, 2025 | 04:04 PM
schuhie's Avatar
I'll have to get a set and try them out. I have had just terrible results with every thing I have tried. Appreciate the response!
Old Mar 29, 2025 | 08:35 AM
CurseDSM's Avatar
What has worked for me in the past is marvels mystery oil. Do an oil change and drop a qt of that in with the oil change and it took the ticking away. Ticking lifters is just the lifters are dirty from bad oil getting sick and clogging the lifters. Try that next oil change and it should work.
Old Apr 30, 2025 | 12:36 PM
turbo R's Avatar
this issue was resolved after spark plug change and the engine is ****ed it still runs but the bearings have gone to ****
Old Apr 30, 2025 | 01:09 PM
CurseDSM's Avatar
Have you pulled the engine apart to verify this? Lifter tick won't cause engine failure.
Old Apr 30, 2025 | 01:14 PM
turbo R's Avatar
yeah removed the oil pan and rod caps to check the bearings and they were very worn I am going to run thicker oil for now hopefully it will work till I can get some money to put forged internals in it
Old Apr 30, 2025 | 01:53 PM
CurseDSM's Avatar
Ok that is a good start, but I would look at better oil quality over thicker oil. Second thing I would do is look to see what may have caused this wear. Oil pump failure, like you said bad oil, neglect of oil changes etc. Once that has been determined id figure out if its just bearings that need to be fixed. If all the surfaces are ok and the bearings are trash then throw a good set of bearings in the car get some GOOD oil not that Brad Penn stuff and call it a day. Brad Penn makes good break in oil and makes from my experience ok oil I would put it up there with Vr1 as a middle of the road stuff. That is just my opinion and my experience so that way people wont get butt hurt about things lol.
Old May 1, 2025 | 01:00 AM
turbo R's Avatar
I can get a replacement engine with low miles for 700$ and a rebuild is going to cost me 500$ without labor so might as well go with a used good one
