Unused Oil Port?
Old Apr 19, 2004 | 08:11 PM
Karash's Avatar
Unused Oil Port?
Trying to figure out how I am going to get my Oil Temp sensor mounted in...does anyone know of an unused oil port I can get an adapter for or how people are hooking their oil temp gauges.
Thanks!
Old Apr 19, 2004 | 10:49 PM
evo81's Avatar
https://www.evolutionm.net/forums/sh...ressure+sender lots of good info on oil temp/pressure.page 2 has an oil temp that looks great.learn it well my young one
Old Apr 19, 2004 | 10:59 PM
ogvw's Avatar
heres mine...
You can use an NPT fitting to adapt your sender (mine is up on the firewall out of the way). I used the other port for my oil temp gauge.
Old Apr 19, 2004 | 11:30 PM
evo81's Avatar
that's nice also
Old Apr 20, 2004 | 12:11 PM
Karash's Avatar
What other port?
Old Apr 20, 2004 | 01:10 PM
ogvw's Avatar
Originally posted by Karash
What other port?
see the one on the opposite side of the filter with the blue wire coming out of it? That is the other port.
Old Apr 20, 2004 | 02:07 PM
Karash's Avatar
ah ok. What size are those ports do you know? Sorry for all the questions.
Old Apr 20, 2004 | 02:10 PM
Karash's Avatar
Greddy Oil Filter Block Part # 12002801
Was thinking about using this...but worried that the filter would be too low to the ground. What do you guys think?
Old Apr 20, 2004 | 03:14 PM
ogvw's Avatar
dont use that filter block...its not needed
you need a 3/8" npt to 1/8" npt adapter bushing - shouldnt be more than $5 ea
Old Apr 20, 2004 | 03:28 PM
Karash's Avatar
3/8"npt for both? (sorry this will be my last question!). I have the Defi BF gauges.
Old Apr 20, 2004 | 03:34 PM
ogvw's Avatar
3/8" npt is what fits in the oil filter flange (both ports) I do not know what size the Defi senders are...
Old Apr 20, 2004 | 04:53 PM
freedom's Avatar
In my opinion the fitting is 3/8" BSPT, not NTP. They are different.
The Defi oil pressure sensor is 1/8" BSPT, while the temp sensor is available in either 1/8" BSPT or 1/8" NPT (different part numbers).
McMaster-Carr sells 3/8 BSPT to 1/8 BSPT bushings for $3 each. To permit the temp sensor to fit you will need to drill out the bushing.
Old Apr 20, 2004 | 05:50 PM
ogvw's Avatar
npt and bspt are VERY close - but npt is much easier to find
Old Apr 28, 2004 | 10:48 AM
Karash's Avatar
Well I was asking more about the Oil TEMP but I might put in a pressure sensor as well.
I went ahead and bought the greddy oil block adapter after getting under my car and deciding that would be the best course of action for a newb. The kit is very well made and has 3 taps in it. 2 1/8 size and a larger one that was labeled "MP" something. All instructions were in Japanese...but you dont need them. Hooked up everything and works like a champ. The filter is lower than before but is not the lowest thing on the underside. I have no fears of it scraping or anything...in fact it looks like it was meant to be that height anyhow.
Oil temp sensor works and I average around 90 C in daily driving and 100 C or so when I drive it hard. Thanks for the tips guys
808_EVO
58
Sep 19, 2012 05:10 AM
I4UnderPressure
49
Aug 11, 2012 04:41 AM
nils
West Region
18
Jul 1, 2010 08:41 AM
06RS
Aug 16, 2007 04:44 PM
LateSleeper
Jul 18, 2004 08:16 AM
