Car stalls at idle when cold -- IAC?
Old Jan 19, 2026 | 12:24 PM
Alacris's Avatar
One more engine problem to diagnose:
Just a week ago, the car started idling very horribly at startup and only holding about 400RPM, on extremely cold days it dies out. If I hold the accelerator at 1500 RPM for about 3 minutes, it warms up enough to idle properly, if a bit rough. After it fully warms up, the idle is fine and everything seems to work great.
Replaced the IAC solenoid about 2 years ago to fix a similar issue. Gave the TB a good cleaning and it worked great afterwards. I guess I could have got a bad IAC that just failed early, but I want to know if there's anything else to check. Originally I had to do the repair quickly, so I used a Duralast part that was a direct fit. I would have preferred OEM but nobody local had them.
Anything else I should check or just see if Autozone will swap out the IAC they gave me?
Thanks.
Old Jan 20, 2026 | 06:20 AM
schuhie's Avatar
Sounds like an IAC to me. I'd see what the warranty on that part is.
Maliphax
Apr 1, 2022 08:44 AM
hamagc
Lancer Engine Tech
19
May 12, 2011 12:46 AM
seatsr4couches
Feb 1, 2011 05:13 PM
ArchieBabes
May 25, 2007 06:09 PM
b18flip
13
Nov 21, 2003 10:09 PM
