Installed stainless clutch line, does this look right?
Old Apr 20, 2004 | 09:09 AM
scottatyamaha's Avatar
I installed the stainless stell clutch line the other say and bleed it. But the clear container that the banjo bolt is at is empty is this supposed to be full of clutch fluid also? Here is a pic a took to show you all.
Attached Thumbnails Installed stainless clutch line, does this look right?-mvc-011s.jpg
Old Apr 20, 2004 | 11:00 AM
Any help...please. All that I need to know is if that smaller clear thing in the back where the banjo bolt is, if it should have clutch fluid in it. Thanks
Old Apr 20, 2004 | 11:06 AM
chinalfr's Avatar
Look ok to me. Any leaks? Can you engage the clutch?
Old Apr 20, 2004 | 11:59 AM
EV0lut10n_8's Avatar
did you bleed the clutch properly to get out all the air? if you bled it properly the whole system would be refilled with fluid. I am not sure that peice is transparent and should show fluid. only way to find out if everything is ok is to put it back together and start the car up to recharge the system and take it for a spin.
YEa clutch engages and drives fine.....but for some reason I remember that thing having fluid in it???
Old Apr 20, 2004 | 12:00 PM
Can someone go look at theres and tell me if theirs has fluid in it... Thanks for the help
Old Apr 20, 2004 | 12:03 PM
i would look if i wasn't 50 miles from my evo right now...i can check this weekend
Old Apr 20, 2004 | 12:04 PM
chinalfr's Avatar
As long as no leak detected, no air bubbles and your clutch engage properly, why worry about other stuff?
BTW, from the look off the pics, the clutch resevior tank looks fill up with brake fluid.
Old Apr 20, 2004 | 12:06 PM
Thats true....but there has to be something wrong for that thing not to have fluid in it though.
Old Apr 20, 2004 | 12:21 PM
mitsuorder's Avatar
Mine looks the same, have had the original Alamo clutch line on mine for about 5 months now I guess
Attached Thumbnails Installed stainless clutch line, does this look right?-p1010161s.jpg
Old Apr 20, 2004 | 12:23 PM
mitsuorder's Avatar
Attached Thumbnails Installed stainless clutch line, does this look right?-p1010162.jpg
Old Apr 20, 2004 | 12:30 PM
ok cool that makes me feel alot better.....thanks alot mitsuorder for your help!
Old Apr 20, 2004 | 12:31 PM
actually now that i think about it...it doesn't have to have fluid in it. that it the attachment from the clutch master cylinder to the resevoir. It controls the flow from the resevoir to the clutch system. As long as the system has enough fluid none should be flowing from the resevoir. make sense?
Old Apr 20, 2004 | 12:33 PM
mitsuorder's Avatar
no problem, I know what it feels like when you are panicing about something that doesn't look right and have no point of reference to compare it to so I'm happy to help. btw, what clutch line is that, the lancershop one?
meric
Apr 29, 2014 10:11 AM
shrty10135
Apr 24, 2014 05:58 AM
yitzac1990
Lancer Tranny/Drivetrain Tech
12
Dec 13, 2010 11:39 AM
Turbo Kyle
10
Sep 1, 2006 11:31 AM
