exhaust manifold
Old Apr 21, 2004 | 03:23 AM
rizalhoo's Avatar
exhaust manifold
hello,
i got a question, im thinking of getting one of the exhaust manifold; im considering to get either the JIC or the Borla exhaust manifold...but im not planning to upgrade the turbo anytime soon though...
i have these mods: cat back, downpipe, intake, bov, ebc, and street tune dynoflash.
oh i will be getting a UR high flow cat too though
so the question is, should i get the exhaust manifold or not? is it worth it ?
anyone can predict how many whp i am now? thanks for the help and info. No flaming pls =)
Old Apr 21, 2004 | 05:19 AM
4G63>OOOO's Avatar
Get it.
Old Apr 21, 2004 | 08:07 AM
chuntington101's Avatar
if you want on for the extra flow, then why not ge the stock ground out. it would be quite easy for a machine shop and woun't cost half as much. i think ther are a few that have done it and seen some good gains. you can do the same thing with the downpipe i think. you could do it yourself if you had the gear!
Old Apr 21, 2004 | 09:49 AM
4G63>OOOO's Avatar
Probably wouldn't flow as well as a true equal length header, though. I see 20psi to redline (7800) with this header and a 3" turboback, for whatever that's worth.
Old Apr 21, 2004 | 12:07 PM
chapter8's Avatar
Your not gonna get that much more power with a true equal length tubular manifold. Your lookin at the neighborhood of 5-10whp on the stock turbo. You will depending if its true equal length gain some spool time to full boost onset (about 300rpm)
If thats important to you get it.
I just like the way it looks
Old Apr 21, 2004 | 01:26 PM
cokofellah's Avatar
Yep, get it....
Have a JIC header in my car...feels great, even exhaust note seems more "solid."
Be prepared for the high temps generated by aftermarket headers. Some guys say not to worry, but....yeah you'll know what I mean.
Currently have DEI insulating tape wrapped around radiator hose as a "band-aid" fix.
Looking into fabricating a steel heat shield...we'll see if its feasible.
Old Apr 21, 2004 | 01:43 PM
rizalhoo's Avatar
oh i thought it should be fine w/o the heat wrap or jet coat or something like that when using the stock turbo? hmmm......any other input?
Old Apr 21, 2004 | 01:48 PM
evoguemr's Avatar
***post deleted*** If you are a private party and have an item for sale, please post it in the for sale forum. It is not appropriate to post it elsewhere.
Old Apr 21, 2004 | 01:49 PM
cokofellah's Avatar
yeah...i believe,however, that there was a reason mitsu had a heat shield on those manifolds.
using my senses, it just feels really hot in that area..and this was just driving "normally" for about 30 mins...
like i've said, some say not to worry... but its my baby, so I worry and react to stuff like that.
to be fair, though, i've never heard of a story wherein a radiator hose blew, or that something in the engine went wrong because of the heat generated by those headers.
its up to you dude...
performance got me to install those though, so....screw the heat, ha, ha
Old Apr 21, 2004 | 01:56 PM
MrBubbler's Avatar
Old Apr 21, 2004 | 02:48 PM
chapter8's Avatar
Yeah thermal coat it, however I really do not reccommend jet coating. There stuff flaked on my car twice. Since then I used these guys http://www.thermaltechcoatings.com/
they are local and there stuff is awesome.
They can even coat the mani in that ceramic silver glossy finish without fading. Jet Coat lasts about 2 days until it turns dull grey. Thermal tech uses a higher silver content in there coating and they sandblast each piece by hand vs Jet Hot that uses a chemical to strip the metal. This in the long run makes the coating less durable.
I noticed a dramatic decrease in under hood temps when I coated my manifold and turbo with the thermal tech
sa215ol
12
May 23, 2012 01:29 PM
Enamor
Lancer Engine Tech
16
May 2, 2009 10:41 PM
Fatal_suicide
Lancer Engine Tech
Sep 6, 2007 10:03 AM
eponti
15
Sep 1, 2007 07:54 PM
recompile
15
Dec 19, 2006 06:59 PM
