weird jolt at 80mph accelerating
On the way into work this morning, cruising around 80mph, wanted to switch lanes and pass a car on the highway. stepped on the gas in 5th gear, started passing the car, then the car felt like it lost all power for a split second, and jolted the car just enough for us to feel it. Literally a split second. What could this have been? First time anything like this has happened, hopefully a fluke.
If you where at WOT and the car "bucked" then continued on, you are describing fuel cut. Fuel cut occurs at 1700 Hz Karman value, 20°C and 1000 mbar atmospheric pressure (roughly 1.2 bars relative boost). At fuel cut the ECU suspends fuel and spark instantly until the triggers clear. That should occur if you have an aftermarket intake and/or exhaust and/or boost controller with cooler weather.
If you car is stock then it may be bad gas or bad plugs.
Speedlimit..
Speedlimit..
my buddy in the car said it made a clunking sound too.. I didnt realize it, was too busy passing the car and wondering what the hell just happened... would fuel cut off make that sound?
Yeah, it was fuel cut.. anything will clunk in the car when you abruptly remove power from the engine.. cold dense air can and a less restrictive/different air filter can definitely cause it..
Fuel cut does not do any damage. One way around it is turn boost down. Another way is with some fuel control, higher flow fuel pump, and larger injector. Also some flashes can remove it.
Originally posted by highvoltz
It's about 50 degrees outside, I have a k&n filter, and boost controller set at 16psi. Sound about right? Why does this fuel cut occur?
Speedlimit..
So I drove down to springfield yesterday, about 50 miles. On the way down it did it twice. On the way back, I got a "service engine soon" light, drove it home 40 miles with absolutely no problems. I don't know if its related or what. I'll have to drive 60 miles to the nearest mitsu dealer. Anything I should do prior?
go to an auto zone or somehting and check the code
if its p0234 then thats the code for a failed wastegate system and it thinks that because the ecu can no longer controll boost
your definately hitting fuel cut
