weird jolt at 80mph accelerating
Old Apr 26, 2004 | 10:08 AM
highvoltz's Avatar
The thing is, I have it set at 16psi. I haven't turned it up from winter yet, so this low it shouldn't be an issue...? Taking it in tomorrow, so we'll see.
Old Apr 26, 2004 | 10:19 AM
Coolguy949's Avatar
What other mods do you have?
Old Apr 26, 2004 | 10:20 AM
highvoltz's Avatar
K&N kone filter... stereo system
Old Apr 27, 2004 | 10:53 AM
highvoltz's Avatar
Ok, the code is p0234. Wastegate. He basically said the light will continue to come on everytime im at WOT. How do I get around this?
Old Apr 27, 2004 | 11:09 AM
JVBEvo5's Avatar
Re: weird jolt at 80mph accelerating
Thats a fuel cut for sure. It might not be your fuel. I had the same problem and it only got worse. I found out my wastegate was stuck. Check it out bro.
Originally posted by highvoltz
On the way into work this morning, cruising around 80mph, wanted to switch lanes and pass a car on the highway. stepped on the gas in 5th gear, started passing the car, then the car felt like it lost all power for a split second, and jolted the car just enough for us to feel it. Literally a split second. What could this have been? First time anything like this has happened, hopefully a fluke.
Old Apr 27, 2004 | 11:40 AM
Shaker Motorsports's Avatar
I had that happen first WOT after my exhaust was installed. No Light on dash, never happened again.
Old Apr 27, 2004 | 11:41 AM
highvoltz's Avatar
It's happened 3 times already... and I have to say its been after I disconnected the negative terminal while I installed my head unit. I dont know if that changed anything... but I don't want to get pumping out p0234's. It's the combinaition of the k&n and boost controller.. so what can be done to stop it?
Old Apr 27, 2004 | 11:45 AM
JVBEvo5's Avatar
Take it to a tuner shop, get it checked out.
Richy2703
Mar 4, 2020 10:11 AM
D1andonlyantman
21
Apr 2, 2016 12:31 PM
TomekEVO
10
Jul 23, 2015 03:12 AM
IWantAnEvo87
Jul 15, 2012 09:43 AM
AK805
Lancer Engine Tech
27
Dec 10, 2007 07:58 PM
