what oil to use for track day?
Old Apr 21, 2004 | 07:11 PM
cityhugo's Avatar
what oil should i use for track day? i was thinking redline, but should i get 10-30 or 10-40, any help? thanks
Old Apr 21, 2004 | 10:50 PM
superz's Avatar
Sup Hugo,
Go with 10-40w or 15-50w, the engine oil gets extremely hot and thin when on a track day. Good luck! Its the most fun you'll have!
Old Apr 22, 2004 | 12:22 AM
TYRONEBIGGUM's Avatar
mobil 1
Old Apr 22, 2004 | 04:17 AM
GDB's Avatar
GDB
Motul 15W-50. Nothing less goes into my engine.
If I don't track my car I could care less what oil goes in as long as it's full synthetic.
Old Apr 22, 2004 | 06:28 PM
Deca Auto's Avatar
whatevers on sale.... jk
Old Apr 22, 2004 | 06:51 PM
Aby@MIL.SPEC's Avatar
mobil1 0/40 or 10/30.
We have had better wear with 0/40 vs 0/30 @ 135C oil in temps. We never lost an engine due to high oil temps either when running mobil 1.
You will sleep better knowing that you have mobil 1 in your sump.
Mobil 1 has made the most power for us, when comparing off the shelf synthetic oils, over quaker state, shell, royal purple.
Old Apr 22, 2004 | 08:53 PM
cityhugo's Avatar
WOT, do u have any exp with redline? I used once on a honda a long time ago, the cold start feels much smoother, but i donno about the protecting engine part
Old Apr 23, 2004 | 09:08 AM
NO
Old Apr 23, 2004 | 10:00 AM
DA-Evo's Avatar
i use redline 15w-50
Old Apr 24, 2004 | 01:10 PM
Ferb's Avatar
Can you post/link to those oil analysis? My fear of M1 is that it is already on the thin side of the range.
And with the 0w-40 long-term viscosity testing showing that it shears then thickens (by oxidation) that doesn't sound good for protecting engines or turbos.
ferb!
Old Apr 24, 2004 | 01:13 PM
jamieritchie's Avatar
check out amsoil
Old Apr 24, 2004 | 01:17 PM
reas0n's Avatar
so these oil are only used for that track day or 2 then suppose to swap back in the mobil 1 10w30 for daily use after...
Old Apr 24, 2004 | 01:44 PM
JFawns's Avatar
A mixture of WD-40 and horse semen has been working miracles for me!
Old Apr 24, 2004 | 02:10 PM
nabit's Avatar
So do you jack the horse off personnal???
Old Apr 24, 2004 | 04:40 PM
Ferb's Avatar
Originally posted by jamieritchie
check out amsoil
I do like amsoil. They really pushed the envelope of oil engineering when they started. When everyone was thinking synthetics would have no place in cars, Joe said they would.
HOWEVER.
I don't like when people pitch the products without backing them up. Unfortunately, i see Amsoil Corp. as doing this on a big scale.
Amsoil makes one of the few non-kart oriented synthetic 2-stroke oils. They make a WIDE range of lubricants.
And i'm sure i sound like a broken record to those who have read my posts before, but what exactly should we look at in amsoil? The amount of marketers on the internet? Or something about the boron chemistry and basestocks (in which case where would i find those?)
ferb!
