HKS 272 cams, Idle AFR
Old Apr 25, 2004 | 06:04 PM
bishiboy's Avatar
I've noticed that when my car is idleing (HKS 272 cams, straight-up (no gears)), my wideband shows drastic swings from super rich (10-11:1) to super lean (20:1). And the rpms surge up and down between 600 and 1200rpms.
Anybody else having this problem?
Anything above idle is excellent, it just idles like ****.
Old Apr 25, 2004 | 06:26 PM
MalibuJack's Avatar
What adjustments have you made for the bigger cams and fuel injectors? The poor idle has to do with cam overlap and possibly the ECU trying to find a miture with the bigger injectors.. I won't speculate any further until you let me know.. If you have not already done so, you might have to get your ECU flashed (or a piggyback or standalone) to scale your injectors otherwise it'll be REALLY rich.. and it'll hunt in closed loop for a good mixture since it may be unable to compensate.
Also, there's a thread on adjustable cam gears, and there have been some possible recommendations for cam timing (-4, -1) to reduce the cam overlap slightly to smooth out the idle.
Old Apr 25, 2004 | 06:38 PM
bishiboy's Avatar
I have a custom tuned dynoflash, although, AL said he doesn't tune for Idle.
I have an HKS S-AFR to adjust idle fuel rates, but before the flash, I actually had to add fuel at idle to help it stablize.
I also noticed that it's not too bad until I turn on the AC or when the cooling fans kick in , then it really runs ****ty.
I saw the thread on the cam gear set-up, but I don't want my car tuned for mid range, I like the top end rush from the cams.
I guess I'll deal with it until I get my UTEC, then I can adjust the idle afr.
I was just hoping for a temp fix.
I'm not giving up. I'll keep messing with the idle air bleed screw and idle fuel amounts.
Shahul X's Avatar
or -4, -1.5
-shahul
Old Apr 25, 2004 | 09:28 PM
umiami80's Avatar
I have 272's, Flashed at Turbo Trixx, idle is ALMOST stock like, very slight lop but is present. I couldn't be happier.
Old Apr 26, 2004 | 05:56 AM
gunzo's Avatar
bishiboy, my AF when the car cannot idle is just like yours
After dialling in .. the AF is around 14.x stable .. occasional stumble shows around 12-13.0 ..
coincidence or cam specs .. but what I had was the similar to what some of the guys found here
Old Apr 26, 2004 | 06:04 AM
nastea1's Avatar
i'm adding about 8% fuel at idle, it seems to help out my 272's its still lopy but..
Old Apr 26, 2004 | 11:11 AM
Shahul X's Avatar
nastea, what are you using ...? an AFC?
-shahul
Old Apr 26, 2004 | 11:13 AM
nastea1's Avatar
s-afr
Old Apr 26, 2004 | 11:15 AM
Shahul X's Avatar
ah, no cam gears? 272 intake as well as exhaust I guess....
-shahul
Old Aug 23, 2004 | 05:35 AM
93civEJ1's Avatar
put mine in this weekend as well. Same exact thing. 272 no gears...same exact idle quality. I did move the idle up a hair but its still pretty much acting the same. Guess its just the nature of these cams without tuning.
Old Aug 23, 2004 | 06:10 AM
superz's Avatar
YOu need to add about +10 to +14 fuel percentages on the safc to get a better idle. That's just the way it goes with cams. Dont worry too much about AFR since the ecu will always try and achieve around a 14:5-8 mixture although this number will fall down or up quite a bit with cams.
Old Aug 23, 2004 | 06:16 AM
93civEJ1's Avatar
yeah.. I really wish adding about 10 or 14 on the safc down low was possible at 0% Throttle, but the car will just correct itself back with it running in closed loop correct??? I have tried this and yet it will just correct itself. A couple of people have mentioned to me about vacuum reserves?
Old Aug 23, 2004 | 06:52 AM
superz's Avatar
At 1000 rpm's its very possible and it wont try and correct since you're actually trying to help the ecu get close to stoch.
Old Aug 23, 2004 | 07:01 AM
93civEJ1's Avatar
hmmm, so are you saying i should up my idle a little more to around 950-1k rpm and adjust the lo throttle 0% tps ?? Each time I do this in closed loop/idle operation it just always seems to adjust itself back. Maybe i should just play with it some more. Hmmmmm i guess i know what ill be doing this afternoon after work today.
