Need Help On Boost Guage Install
Old Apr 30, 2004 | 09:28 AM
Villan's Avatar
I need to know which wire to tap in order for the boost guage light to dim with the instrument cluster when the headlights are turned on. I read a while back that it is suppose to be a white wire with a green stripe. Can anyone confirm this? BTW, the guage will be installed on the steering column if that's going to make a difference. Thanks in advance.
Old Apr 30, 2004 | 08:45 PM
Appauldd's Avatar
I wired mine into the dimmer switch. But I never dim the lights so I am not sure which wire will do it. I think you are correct though. Try it. f it doesn't work it is the other wire. The dimmer switch has 3 wires. Trial and Error.
Old Apr 30, 2004 | 08:50 PM
Villan's Avatar
Which wire did you tap in your install? So that in this case, I only have 2 wires to worry about.
Old May 2, 2004 | 10:10 PM
timzcat's Avatar
Provide power to the gauge bulb and put the ground on the black/yellow wire.
The dimmer varies the resistance to groud, it does not supply the power to the bulbs.
Edit: Easiest thing to do is use the Green white wire for power. That way the light turns on with the lights and Dims with them too.
Old May 4, 2004 | 10:13 AM
Scud!'s Avatar
Thumbs up
Why not tap into your ciggy lighter lights? it's the same.
Old May 4, 2004 | 11:10 AM
Villan's Avatar
I don't know. I just figured that it will be less work if I tap into a wire close to the steering column since I will be installing the guage pod on it.
TS Goofy
Dec 13, 2013 08:28 PM
evo 9 guy
Nov 16, 2010 11:49 AM
►EvolutionX◄
Apr 14, 2009 10:32 PM
Green_Bandit
Nov 3, 2008 09:31 PM
hennessey01
Jun 22, 2008 11:58 PM
