Mini Battery $75.00
Mini Battery $75.00
My friend just put this on his car 75.00 plus shipping. Instead of spending tons of money on a kit. So those of you wanting a shorter Upper IC pipe and need this kit. This works well.
http://www.portablepower.com/Product...ctNum=37L105S1
http://www.portablepower.com/Product...ctNum=30Z101B1
The factory post will not adapt to that. Also I doubt it will ever crank a car since everything else listed is for ATV's,Mowers, or any other small type of equipment. Plus you will need the mounting plate and hardware.
Actually that battery could be adapted to use standard SAE posts quite easily. The second link shows the SAE adapters. Also, it would probably be okay to start the car. However, it's not really fair to compare the Hawker Odyssey 680 with the XStatic Batcap Model 800. The Batcap has 800 CCA versus the Odyssey 680 rated @ 220 CCA.
Just thought I would throw this out there. No, not the same, but comparable. Seems to be working just fine. The car that it was in just finished 2nd in the Open Track Challenge. Yes it will crank and it works great. Everything fits just fine. With a little bit of DIY, it will work fine. The DIY work for the battery will definately be better than the $200.00+ for other kits. No offense JRod, but some of us don't want to spend that kind of money on a battery kit.
Z1 Performance
Evo 'For Sale' Suspension / Brakes / Handling
33
Feb 5, 2004 07:48 PM
