dont wash your motor, it will start skipping
Old May 7, 2004 | 08:30 PM
ryan t's Avatar
washed my motor and the spark plug holes filled up with water and motor started skipping went back to dealer and they dried it out and cleaned spark plugs, now after i drive about 20 minutes it starts skipping again any ideas
Old May 7, 2004 | 08:34 PM
Keyser Soze's Avatar
You should have covered all electric and spark plugs before you wash your engine to avoid water getting in these areas
Old May 7, 2004 | 08:35 PM
naucrx's Avatar
There's probably still water in there somewhere. I say pull the plug wires out and let it sit for a day to dry out.
I agree with RaleighEVO. It's best to cover up the distributor and spark plugs/wires when spraying off your engine.
Old May 7, 2004 | 08:45 PM
Quickshift's Avatar
Get some WD-40 (wd=water displacement) spray it into the all the electrical connection and let it sit for a little bit. That will dry it good. Ive done this before ,but I didnt rely spray the engine water directly.
Old May 7, 2004 | 08:51 PM
nick735's Avatar
The evos ment to get wet we have a fricken hole in our hood
Old May 7, 2004 | 09:00 PM
Wrench's Avatar
Use you sister's hair dryer to dry them off...........
Old May 7, 2004 | 09:04 PM
Yea Get Wet! LOL not directly sprayed at by a Hose
Old May 8, 2004 | 01:57 AM
Creamo3's Avatar
Old May 8, 2004 | 09:24 PM
GREDDY's Avatar
What do you mean your motor started skipping.
Old May 9, 2004 | 08:18 PM
Schmitty's Avatar
Skip to my loo? Its HAPPY! I would park it in the sun with the hood open and let it sit for a few hours.
Old May 9, 2004 | 08:26 PM
babyboba29's Avatar
i had hydrolock in my lancer by means of the cold air suckin in water and the motor didn't idle smoothly, the motor "skipped" and stalled. a crap load of carbon build up was on my exhaust. see if you have the same symptoms. i would take off the valve cover and blow dry everything until there isn't any water. careful though, i dunno about the evo's valve cover, but the lancer's cover is three layers of pressed aluminum and the water sits in between those layers. so even if it looks and feels dry, there is still water. good luck to you and hope the same thing that happened to me doesn't happen to you.
moyassine
Feb 21, 2016 10:54 AM
aloharonaldo
Jan 28, 2015 09:08 PM
need_an_evo
Sep 8, 2014 06:50 AM
Oracle1
Oct 1, 2011 01:07 PM
