Help! Anyone know where O2 sensor wiring harness clip is?
Old May 8, 2004 | 07:00 PM
midwestmonster's Avatar
I just had a clutch put in and all of a sudden my check engine light is on. The code read was because of the second O2 sensor. I have a ultimate racings test pipe on my car, but before I had my clutch put in, no CEL for atleast 800-900 miles. I think when the clutch put in they might have disconnected the harness or something. Don't most cars have a wire clip you plug in or something? I remember my honda did....Any help would be appreciated. I cant find this harness clip anywhere to see if they disconnected it or not. Thanks.
Old May 8, 2004 | 07:06 PM
kuniboy's Avatar
why don't you reset the code 1st and see if it comes back on immedieatly. I doubt the clip came off. its located next to the gear shifter, inside the car.
Old May 8, 2004 | 07:09 PM
I did that like three times and it always comes back on. The ultimate racing test pipe is supposed to not give a CEL, and it didn't until I had the clutch put in. I can't imagine why it is now....
Old May 8, 2004 | 07:13 PM
Bump
Old May 8, 2004 | 07:38 PM
kuniboy's Avatar
what code is it? R U sure its the secondary o2 sensor??
Old May 8, 2004 | 08:08 PM
GTVEVO's Avatar
if you are looking for the rear 02 sensor harness connection it is under the passanger seat on the left side under that carpet but their is a slit in it so you can reach under the carpet and pull the plug out. I hope this helps, atleast you can check and rule it out.
05EV08
May 8, 2016 11:32 AM
fi8tzer0
Nov 23, 2015 11:15 PM
pushdragon
Jun 6, 2009 01:32 AM
vtluu
15
Feb 7, 2008 09:40 PM
morgo333
Oct 19, 2006 01:17 AM
